| Power Steering Fan Shroud |
| This info can be found in the following Did You Know? ... http://www.mini2.com/forum/showthrea...32#post1780232 |
New guard fitted Pump fan did not work after fitting guard thought I had done something wrong Left engine running and warmed it up and the pump fan runs at the same time as the radiator cooling fan So it seems that the pump fan does not run continuosly to cool the pump motor. Also when you take the fan out there is nothing behind it Suspose all it does it create a draft to help the airflow oin the pump area??Cuple of pics before and after |
| power steering fan. | holdenontoit | First Generation Faults & Fixes | 5 | Jan 17th, 2006 09:45 PM |
| Power steering fan is gone! | thanos30 | First Generation Faults & Fixes | 4 | Mar 21st, 2005 06:07 PM |
| I don't have a power steering fan! | Dom | General Discussion | 20 | Mar 19th, 2005 12:11 PM |
| Cobalt Power Steering Fan Shroud | hjacobs475 | First Generation Faults & Fixes | 4 | Aug 25th, 2004 07:06 PM |
| Power Steering Fan Shroud | MINIAC | First Generation Faults & Fixes | 10 | Aug 14th, 2003 08:42 PM |
