Think Mini
Old Aug 20th, 2005, 06:07 PM   #1
heo1977
Cooper S
heo1977's Avatar
Local Time: 10:59 PM
How to get rid of the air when i change the cooling liquid at my "S"
I had brown water at the cooling system at my Cooper S so i bought a cleaning kit for the system. The tank had also a leak so I bought a new one.
When I should fill on the new cooling liquid I don't get more than 3 litres into it... There shall be 6 litres at it.
I god about 1,5 litres into the tank and about 1,5 litres in by the air screw at the front of the car on that water hose.,.
So, I have to get in another 3 litres but it seems to be full everywhere..
I opened the hose at the bottom of the radiator to get of the old water.
Any tips?
Regards
Hans Erik
Norway
Norway View heo1977's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 20th, 2005, 11:58 PM   #2 (permalink)
Lanfear
Beep!
Lanfear's Avatar
Local Time: 05:59 PM
Send a message via ICQ to Lanfear Send a message via AIM to Lanfear Send a message via MSN to Lanfear Send a message via Skype™ to Lanfear
Any tips?
Regards
Hans Erik
Norway
With my previous car, I would start the car with the rad cap off and keep it running until I started to see the coolant circulate with bubbles coming to the surface. I would continue filling until the rad was almost full to the brim, then I would rev the car (to make the coolant level in the rad go down a little), pour more coolant in, put the cap on, and ease up on the throttle after the cap is on securely.
I'm not sure how this would be done with the MINI. It could be completely different.
Canada Female View Lanfear's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 22nd, 2005, 02:14 AM   #3 (permalink)
Lanfear
Beep!
Lanfear's Avatar
Quote: Originally Posted by Max
It's the same. Run the engine gently a bit and the level should drop as coolant is pumped into all areas of the system. Then keep topping up. Then give a few high revs, then top up again.
Finally replace the expansion bottle cap.
Go for a drive to normal driving speed, keeping an eye on the temperature guage. Ensure to take some spare coolant with you.
After this, let the engine cool down, check the level and top up to between the Max and Min marks.
If you remove the expansion bottle cap when the engine is hot take care.
Thereafter check the coolant level weekly when you check oil level and lights etc
I'm glad to know it's all the same. Hopefully I won't need to use my old tricks any time soon though. My previous car had a real problem with the cooling system.
Old Aug 22nd, 2005, 07:32 AM   #4 (permalink)
moonshine
moonshine's Avatar
Local Time: 09:59 PM
DIY
there are also 2 plastic screws om the coolant hose to assist with bleeding air. - on the cooper one is about 12" left of centre of the engine, on the hose that runs along the top of the bay, as you would look at the engine if standing at the front, with the bonnet open. IIRC, there is a second one about 12" to the right, but burried somewhere lower down in a hose somewhere.
When my radiator cracked all the coolant was locked and the BMW assist man came out and topped up the radiator - he then bled the system with these screws and the header tank cap off and the engine running
I don't know how the mini cooling system works, but i know some cars need to have the system bled - my brother in laws race Caterham has a Rover K-series engine and it requires to be bled after a radiator coolant change - one time we forgot and blew the head gasket - OOPS!
Gerry
MINI Cooper, Chili Pack, Xenons, heated washers, MFSW, ASC+T,
Scotland Male View moonshine's Indi Blue & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Aug 23rd, 2005, 03:53 PM   #5 (permalink)
heo1977
Cooper S
heo1977's Avatar
No air..
I found out that there is a plug under the exhaust manifold that I must open to get out the water from the engine. I thougth that all the water came out when I opened the hose at the bottom of the radiator but I was wrong.
That plug is over the cooling fan to the servo pump and it is a h... to screw it out so I'm doing it the easy way, driving to the Mini garage tomorrow so maybe I can try a new BMW in the meantime!
Thank you everyone.
Hans Erik
"S" Oil change -- drain plug washer? homebruin Maintenance & MINI Care 6 Mar 1st, 2005 03:32 PM
Red Flag? 10+ Day "Oil Change" at VDC ZenAudio MINI Convertible 18 Sep 20th, 2004 01:58 PM
"Anyone" Really waiting 10K Miles Oil Change? Vincent Hill Maintenance & MINI Care 240 Apr 30th, 2004 08:51 PM
UPDATE: TIRES TYRES & WHEELS FIXED... D'Oh, - No, No!... Help: 17" to 15" Change SugarBelly Wheels, Tyres & Brakes 11 Aug 31st, 2003 11:32 PM
