FOMSPORT
Old Jun 25th, 2002, 07:51 PM   #1
frails
Posts: n/a
The Answer to the Oil Filter Question
Oil Filter Change Procedure
For all you DIY people and those that take their MINI’s to a lube shop, this procedure will answer vital questions about how to install the new oil filter. I would suggest you verify the procedure with your MINI service people before just taking my word for it.
The filter design was changed in some small ways so that the same filter could be used in a standard Cooper and an “S”. Standardization is a good thing, but without the correct installation instructions, some of us could risk serious damage to our engines. So here it is:
1. Remove the plastic seal and tube part from the upper end of the old filter. Do not dispose of this piece.
2. Insert and seat the plastic seal and tube over the spring in the housing cap so that the tube will go up inside of the new filter.
3. Install the new filter on to the plastic tube and push it all the way down. (this is with the non-seal end going on to the tube. The hole is a little small so some force is required.)
4. Replace the "O" ring seal on the housing cap with the new one provided.
5. When the housing cap, spring, seal and tube and filter assembly is complete, place the filter over the metal tube coming up from the housing base and screw the housing cap and its contents onto the housing base.
Visit my Blog at the Motorcade   Reply With Quote
Old Jun 26th, 2002, 04:35 AM   #2 (permalink)
Paul
Trained Monkey
Paul's Avatar
Local Time: 10:04 AM
Thanks Frials.
Glad you got there in the end!
Old Jun 26th, 2002, 07:39 PM   #3 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 02:04 AM
It would be much appreciated if the next person to do this would take some digital pictures ... and put together a FAQ
Old Jun 26th, 2002, 09:25 PM   #4 (permalink)
Apex
Apex's Avatar
Local Time: 05:04 AM
So, I guess I shouldn't let Moe and Zeke's garage change my oil and filter??
'02 Cooper, BRG/white, Premium pkg., Sport pkg., chrome bumpers.
United States View Apex's British Racing Green & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jul 2nd, 2002, 12:02 AM   #5 (permalink)
dennis
Local Time: 09:04 AM
Re: The Answer to the Oil Filter Question
__________________________
Seems like you may have skipped some steps prior to this. The filter is located inside a canister for which, as I understand from previous threads, you need a 13 mm wrench to open the canister, which is accessible from the top.
The rest of your instructions seem complicated, especially since I was given a pleated filter insert with a "O" ring seal. Oddly enough, the part number of the pleated filter is 11 42 7 509 208 compared with the number labelled on the box which is (correctly) 11 42 7 512 446.
Something isn't right here.
Old Jul 2nd, 2002, 06:45 AM   #6 (permalink)
Sealevel
Local Time: 04:04 AM
And in the future the very best time to research and post The Answer is before posting The Statement--such as "Oil Change Voids Warranty"--which others took weeks to clear up for you along with providing the information you've now copied onto this post.
Steve
Cooper S: Pure silver/black, Premium, Sport, Black leatherette, 17" R90, 4/19 build, 5/24 delivery.
Old Jul 2nd, 2002, 08:02 AM   #7 (permalink)
Sealevel
Re: Re: The Answer to the Oil Filter Question
see posts by Juanello and Sealevel here:
http://www.mini2.com/forum/showthrea...t=oil+filt er
dennis--the wrench or socket needed to remove the canister is 36mm, the largest 1/2" drive socket commonly stocked, for one of the smallest cars on the road! frails description doesn't quite match the experience I had either, so I'm also now a little confused about what, if any, changes have occurred. My impression of the tube he describes is that it was part of the canister itself. It didn't come off with the old filter element, or during the "pre-fit" of the filter to enlarge the holes in the ends. The filter part # on my receipt and the box was the one you list that ends with 446, and I recall confirming it on the filter itself. The filter element I used matched your description though. About the complicated instructions, I can tell you it's indeed hard to describe, but becomes clear when you do it, noting how the old filter was intalled before removing it from the canister. And until The New Answer emerges, obviously it's necessary to call a MINI parts department for the story on the filter # discrepancy and verify you indeed have the right part before getting started.
Steve
Old Jul 3rd, 2002, 12:51 AM   #8 (permalink)
dennis
Re: Re: Re: The Answer to the Oil Filter Question
[quote]Originally posted by Sealevel
[b]
dennis--the wrench or socket needed to remove the canister is 36mm...
_______________
I stand corrected. Thanks. I was thinking of the drain plug gasket size. As you say, the only way to figure this one out is to actually try changing the filter element and see how the old one was inserted.
Old Jul 8th, 2002, 11:44 PM   #9 (permalink)
frails
Posts: n/a
Not Sure What To Make Of This
Seems like Sealevel is a little put out with me. Something about me taking other people's information and posting it as my own.
The instructions for installing a new oil filter may have appeared in one of the threads, I guess they must have. However, I did not see them. Had I known they were already there someplace, I would never have asked the question about installing filters and would certainly not repost them under my name.
I got my filter instructions by calling no less than 10 dealerships before one of them was able to share the correct method with me. I was amazed at the number of dealerships that have not yet done a 10,000 mile service.
I took the MINI Mechanics instructions and checked them out at my local lube shop when we had the old filter out to see for myself what was going on. Only after doing this did I post the information.
I value this forum very much and if in fact I accidentally did as Sealevel believes, I appologize. And many thanks to the people who responded with helpful suggestions to my other questions.
Reputable & affordable place to get my oil/oil filter changed spmprnl MINI Cooper S 1 Feb 12th, 2007 03:39 PM
Oil Filter question BobV Maintenance & MINI Care 3 Mar 21st, 2006 02:19 AM
do i need to change oil filter when changing engine oil? asinn Maintenance & MINI Care 6 Jan 27th, 2005 04:20 PM
Another Oil Change Filter question HELP! odieone Maintenance & MINI Care 4 Apr 9th, 2003 11:30 AM
changed my engine oil and oil filter today :D erichui Maintenance & MINI Care 15 Dec 23rd, 2002 08:56 AM
