| MINI Clubman MINI Clubman 2007 - Present |
| MINI Clubman "Flat Load Boot Floor" Can someone please post pictures or explain what the "flat loading boot floor" actually does? I understand that it makes the boot the same height as the rear seats when they are folded down. Is it a piece that is removable or is it a permanent feature? If you don't choose this option, can you buy something through the OEM MINI parts department to add it later? And if you don't have this option, is it a boot just like the R56 but larger? ![]() In Canada, it's called the "flat loading floor" and it's part of the "Travel Package" - which is new for the Clubman in 2008. My name is Christina. I am living my dream! I drive Stella: AB 06 MCS w/ pink bonnets, roof, & pink u/j mirrors ! I work @ MINI in Canada. Confessions of a MINIac. |
| At the VIP launch day at the factory I had a fiddle with this addition. Its very clever. I had a chance to remove it from the demo one I had a play with just to see if it was removable as I felt it may get in the way if you wanted the deeper boot without putting the seats down but very useful when you want the seats down with a flat loading area. It also protects the bottom of the seats (especially useful if they are leather) when they are down which currently doesn't happen in the hatch. Any more questions feel free to ask and I'll see if I can answer. Don't know about the after addition to the car after built though. ![]() |
| Have a look here http://www.mini2.com/2007/09/07/mini...t-from-madrid/ Theres a good picture and some details in Pauls report from Madrid. The parcel shelf has come in for some critisism but I like the design, the way it has sprung resistance helping it stay taught is very good. |
| Thanks for your help ![]() Also, do you know if it's available as an accessory? If it's not ordered from the factory, can it be retrofitted/purchased later? My name is Christina. I am living my dream! I drive Stella: AB 06 MCS w/ pink bonnets, roof, & pink u/j mirrors ! I work @ MINI in Canada. Confessions of a MINIac. |
| My guess is that it would be significantly cheaper to specify with your order. Remember that awfully nice concertinating false floor needs to hang on to the side somehow. BMW's solution is to attach a baton ar each side. If you fix a baton at each side, it might not look quite so good. |
| I have the flat load floor option, the floor is very easy to remove, it is just attached with a couple of bits of velcro and a pair of 'lugs' which slot into a side rail similar to that on the load area cover. I find it handy for storing stuff under the flat floor, and then put my regular luggage ontop of the flat floor. Here are a couple of pics of my boot space: |
| Tags: boot, clubman, flat, floor, load |
| MINI Clubman "compilation" video | Paul | MINI Clubman | 0 | Jul 30th, 2007 02:23 PM |
| MINI Clubman "Video" online | Paul | MINI in the Media | 1 | Jul 28th, 2007 05:35 PM |
| Where can I get new bonnet/boot badges to replace the "MINI wing" ones? | MINI Girl (USA) | First Generation MINI Exterior | 8 | Sep 29th, 2006 03:06 PM |
| where can I get a "WOODY" Mini Clubman? | taz2822 | General Discussion | 5 | Apr 1st, 2005 05:59 AM |
| Problem With MINI "Boot Box" Accessory | kshapiro | First Generation Faults & Fixes | 15 | Sep 14th, 2002 02:36 PM |
