| MINI Clubman MINI Clubman 2007 - Present |
| Runflat tyres are standard on the Cooper S whether you have 17 or 16 inch wheels. Therefore, you can run on them for 100 miles at a reduced speed of 50 mph MAX. This is with no air pressure in the tyre whatsoever. Hope this helps ![]() Oh btw... welcome to MINI2 |
| When I changed my S to non runfalts I put a can of tyre foam and a small compressor in the boot just in case. The extra space under the floor is so usefull I have 15's (not runflats) so I have the Mini Mobility kit I believe its called and a whole load of polystyrene foam to hold all the bits and pieces screwdriver locking nut etc I intend to dump the moulded stuff and get a bag for all the kit freeing up even more storgae space. Welcome to the world of Clubman by the way. I have a set of 17" allloys in the garage I intend to use them in summer and will probably put one of the 15"s in the boot for longer journeys as a spare. |
| Tags: help |
| The deed is done...Changed our order from Cooper Clubman to a Cooper S Clubman | JustACooperClubman | MINI Clubman | 11 | May 19th, 2008 08:52 AM |
| My Clubman | Shaun | MINI Clubman | 23 | Mar 23rd, 2008 03:52 PM |
| New boy with Clubman 'S' | del115 | MINI Clubman | 10 | Jan 11th, 2008 11:08 AM |
| Clubman - so what do we think? | MiniOneSam | MINI Clubman | 27 | Nov 13th, 2007 09:45 PM |
| Clubman | Hat | MINI Clubman | 4 | Aug 27th, 2006 02:30 PM |
