| MINI Clubman MINI Clubman 2007 - Present |
| Rubber seals on rear door windows Has anyone experienced probelems with broken / split rubber seals on the clubman's rear doors? The rubber seals at the bottom of both windows (the section of rubber below where the wipers rest and above a chrome strip) on my clubman are both split along their lengths for between 4 to 6 inches from the outside. At first glance there doesn't appear to be a problem as the upper piece of rubber still lies along the chrome strip and when you lift them the lower bit is still inside - I only noticed it when washing the car recently. Don't think it is vandalism as they would probably have done more obvious damage e.g. to the wipers. I think the seals have just perished - after one year! I don't use a pressure washer or car wash - just a light hosing and bucket & sponge job - so that won't have caused it either. No apparent signs of water ingress or rust to the rear doors but obviously needs checking / replacing by my dealer. It's a Sept 2008 Clubman D - great car by the way. Just thought I'd check in case anyone else has had this problem and might be worth checking yours just in case. Cheers, Gary |
| Booked in to be done on Friday 28th August. The dealer didn't seem to 'bat an eyelid' when I booked it so hopefully there will be no problem - I half expected them suggesting that it had been vandalism or misuse by me. Will update after Friday when I find out what the cause / fault actually is. |
| I have exactly the same problem. My passenger-side barn door has lost all of the rubber outside of the chrome beltline. The driver-side is perfect. I didn't want to take the car in just to repair that, so I had them send me a new rubber seal. Still don't quite know how to pull the chrome off safely. Maybe I should take it in after all. BTW - this is my first post on the forum. Hope I'm not running afoul of any posting etiquette. |
| Fixed today by dealer (Preston Hall MINI, Stockton-on-Tees). Only took them about 25 mins - they were so quick that I was taken by surprise when they gave me the keys back and I forgot to ask exactly what the problem had been. I think they said that they had re-seated and resealed the seals. From what I can tell the upper part of the seal is actually glued or bonded to the glass and the lower part just clips onto the chrome, so I think that they have just re-glued the upper sections as the seals look like the original ones (there was nothing wrong with them so didn't need changing). Anyway, all sorted, no quibbles, quite happy! |
| Tags: door, rubber, seal |
| Water leak - door seals | trucker | First Generation Faults & Fixes | 17 | Jun 22nd, 2011 10:19 PM |
| Corroding door seals | brinks | Maintenance & MINI Care | 2 | Mar 5th, 2009 04:09 PM |
| Screen Wash in Boot Rubber Seals ? | Perm | First Generation Faults & Fixes | 0 | Jan 15th, 2009 11:10 AM |
| Very Annoyed - Door Seals! - Had Probs Yourself? | K9COOP | First Generation Faults & Fixes | 5 | Oct 30th, 2005 09:31 AM |
| Creaking Windows/door Seals. | rayasp | First Generation Faults & Fixes | 2 | Aug 22nd, 2002 11:28 AM |
