| MINI Clubman MINI Clubman 2007 - Present |
| Hi all, first post so appologies if I am going over old ground. Got the new clubman yesterday, now I am sure when I looked at the car when you pressed the rear door button both doors opened, however I now find only the driver door opens when I press the button. Am i missing something???? |
That's right, you press the right-hand door button and it opens, the left-hand one remaining locked until you then press that one. After all, you don't always want both doors open, if for example you want to quickly get something out or put something in you often only want one open. |
Opening rear door by key. On my Clubman, the rear right hand door opens when you press the boot symbol on the key, but you then have to open the left hand door manually - is this correct? If both doors SHOULD open then I have a fault. Would appreciate confirmation... |
| That is correct, yours appears to work as designed. Mine works this way and the demos I tried before I bought it. |
| Tags: clubman, rear doors |
| Split rear door remote opening? | MrDNA | MINI Clubman | 5 | Sep 7th, 2010 10:29 PM |
| Random Rear/side door opening | notcmartin | MINI Clubman | 5 | Mar 9th, 2010 01:50 PM |
| Clubman Rear Door Stuck | daro911 | Second Generation Faults & Fixes | 0 | Oct 1st, 2009 05:25 PM |
| Our 1st exclusive clubman part - carbon rear door handles | mikeythemini | MINI Clubman | 15 | Sep 15th, 2008 12:05 PM |
| Clubman S Rear door reflectors | Gemini2008 | MINI Clubman | 6 | Aug 28th, 2008 08:05 AM |
