Knocking Clubman 08 Cooper S - I need help! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Clubman
MINI Clubman MINI Clubman 2007 - Present
Old Jan 10th, 2012, 05:17 PM
Local Time: 12:58 AM
I’ve recently purchased a Cooper S Clubman and I absolutely love it! However, I have strange knocking sound on the rear passenger side that sounds like a loose piece of wood every time I go over a bump. I’ve taken the parcel shelf cover out and jack etc and it’s still there. The right side is fine!
The car went into BMW last week and they replaced the rear bushes, but the knocking is there! It’s going back in on Friday. What’s even stranger is that when the car was return it’s developed a strange sound that emanates from the centre console and happens about every five minutes. It sounds like a small crow in the centre console!
Update - After nearly 24 hours spent on the car the dealer finally found and rectified both problems:
Centre console: the pollen filter was pushed to far up and was hitting the heating fans. Solved after the 5th visit.
Rear knocking: This was tracked back to a loose bolt on the rear seat belt. Solved after the 7th visit and a 4 page complaint letter.
Now I'm very happy!
Old Jan 10th, 2012, 07:01 PM
United Kingdom Female
I'm not sure if the Clubbie has the same catches but the rear seat catches often make a clunking noise if they are badly adjusted or dry. The dealers usually put copper grease on them or adjust them a bit and the noise goes away- until next time
Is the 'crow' your climate control changing flow direction? Obviously, ignore this if you haven't got auto aircon.
Old Jan 14th, 2012, 08:29 AM
RobbieA's Avatar
England
United-Kingdom
I don't know if this is the answer or not but I had a knocking/rattle noise on the near side rear which turned out to be the rear passenger seat belt buckle hitting the side panel. I just make sure it's tucked in between the seat and panel and this has solved the problem.
Old Jan 18th, 2012, 08:10 PM
BlackMiniMac's Avatar
Caution!! Girl Racer!!
United Kingdom Female View BlackMiniMac's Lightning Blue & Silver 2nd Gen MINI Cooper S Clubman Profile
Was the rear 'bushes' on mine. Made hell of a noise
Good girls are just bad girls who haven't been caught yet.
Old Mar 9th, 2012, 05:42 PM
Solved!!!!!!!!!
Update - After nearly 24 hours spent on the car the finally found and rectified both problems:
Now I'm very happy!
2002 Cooper S Engine Bay Knocking Mike Smith First Generation MINI Cooper S 3 Sep 2nd, 2009 05:17 PM
URGENT - 08 Cooper S - considerable knocking from engine jason_macq Second Generation Faults & Fixes 4 Jan 6th, 2009 09:13 AM
The deed is done...Changed our order from Cooper Clubman to a Cooper S Clubman JustACooperClubman MINI Clubman 11 May 19th, 2008 08:52 AM
02' Cooper Bizzare Knocking Noise Started Today!? daniel_davies First Generation Faults & Fixes 3 Dec 21st, 2007 09:37 PM
Knocking noise from front on 05 cooper s 14k miles bards First Generation Faults & Fixes 5 Jun 22nd, 2007 03:47 AM
