Safely Lifting 09 (UK) Clubman - MINI Cooper Forum
MINI Clubman MINI Clubman 2007 - Present
post #1 of 5 (permalink) Old Jan 9th, 2014, 10:56 AM Thread Starter
Local Time: 02:15 AM
Morning Folks,
I have tried a search in here for info on how to safely jack my wife's 09 MCS Clubman (UK) and can't find anything.
I have a very good quality trolley jack, and would like guidance on the safest and stable point to jack it up. I need to take the alloys off and give them a proper clean as it is new to us.
Many thanks.
Paul
Gti Jazz Blue is offline
post #2 of 5 (permalink) Old Jan 9th, 2014, 11:06 AM
Quoted: 40 Post(s)
If the trolley jack has a reasonably large lifting pad/cup, you will find it fits over the bottom of any of the four lifting points under the sills - these are black plastic boxes, maybe 2" deep, that stick down from the sill and they have a recess that the car's screw jack fits into.
Except if you scrape these lifting points off by driving over rough ground (as I have done), they seem to be extremely secure, even if they are only plastic.
If you jack the one behind the front wheel high enough, the front and rear wheels will both come off the ground.
Angib is offline
post #3 of 5 (permalink) Old Jan 9th, 2014, 11:12 AM
Quoted: 40 Post(s)
Err, it dawns on me that you have said Clubman, in which case the front jacking point may well not lift the rear wheel too - I don't know.
Angib is offline
post #4 of 5 (permalink) Old Jan 10th, 2014, 03:08 AM
Lightweight
ravioliworld's Avatar
Local Time: 10:15 PM
United States Male View ravioliworld's Hyper Blue & White 1st Gen MINI Cooper S Profile
I like to throw a piece of lumber under the sill inbetween the two jack points. Jack placed midway down the door. Lifts both front and rear wheels, and you can place jackstands under the actual jacking points. Lumber helps to spread out the load and prevent the jack from damaging the sill.
blergh
ravioliworld is offline
post #5 of 5 (permalink) Old Feb 5th, 2014, 08:08 AM Thread Starter
Well finally had some time when it wasn't raining, so created some hardwood inserts for the OEM jacking points and successfully lifted the Clubman.
Great start managed to get the first wheel off fine, cleaned it up as best as possible, outside fine, inner part of the wheel was in a very bad state. Did my best in the limited time I had.
Then the bad news, couldn't manage to get the rear off of the hub, even used a tyre fitters sand filled hammer to try and free it. No joy and I could only hit it so hard whilst up on the trolley- jack. So looks like I will need to get a pro to sort that on a proper lift.
So I continued with the car back on the ground - to find that a really bad touch-up job had been done to sort the wheel damage for sale. I could feel the moment I got the polish on a matt finish at the edges. They had blended it into the shadow line on the wheels. So not to impressed.
Clubman third braking light how to remove? juge MINI Clubman 3 Feb 5th, 2017 05:11 PM
Problems with a 2009 Clubman S w/ 106,000 km nickh MINI Clubman 1 Oct 10th, 2013 11:55 AM
New Mini Clubman Owner Sammo123 Welcome New Members 5 Sep 18th, 2013 09:54 PM
Battling with JCW Countryman and JCW Clubman Onsdoo Northern California Region 3 Mar 5th, 2013 11:42 PM
