Shifting Gears - HELP - MINI Cooper Forum
MINI Clubman MINI Clubman 2007 - Present
post #1 of 2 (permalink) Old Jun 24th, 2014, 02:34 AM Thread Starter
Local Time: 03:09 PM
Canada
I just purchased a 2009 Clubman with a manual transmission. I have never driven manual until a one hour lesson last week! I learned on a Ford something-or-other and I will tell you there is a HUGE difference. Mini's are tighter and there is far less wiggle room. I have the hang of everything except I am not happy with my shifting. It sounds too aggressive. I find that I need to be in 2nd almost immediately (around 30km/hr) and then 3rd only keeps my car happy until about 50-60km/hour and I need to shift to 4th. I was on the highway doing 110 km/hr in 4th but would absolutely need to go up to 5th to do my usual 125-130 km/hr.
So, I guess my question has 2 parts - what RPM ranges should I be looking at for gear changes and how do you make them SMOOTH?
I would also like to add, my car came with a french manual which is less than zero help to me - which is why i'm asking this here.
Thanks!
muscleboundmama is offline
post #2 of 2 (permalink) Old Jun 24th, 2014, 06:32 AM
Local Time: 08:09 PM
Quoted: 53 Post(s)
Some MINI rev counters do have the ideal gear number illuminate when you should change gear for the best performance and economy, maybe yours needs setting up?
Smoothness comes with practice, perhaps you should go out with someone who already drives a manual change and let them give you a few tips and a demonstration??
I thought you were going to say your car came with a French Maid because that would be ideal
On line copies of the manuals can be found here:
manuals | library of motoring - An online collection of MINI information
Owner's Manual (2009 Clubman)
2009 Clubman
The Nun is offline
Transmission problem. Lower gears hesitation? brendenm First Generation MINI Cooper 0 Apr 27th, 2014 01:48 PM
Mini One 2001 1.6 Auto Not selecting gears after battery disconnected Tdci_boy First Generation Faults & Fixes 5 Aug 15th, 2013 08:28 PM
Grinds My Gears Mad_Max_Subie First Generation MINI Tuning 2 Feb 21st, 2013 04:56 PM
