Engine misfire on acceleration - MINI Cooper Forum
MINI Clubman MINI Clubman 2007 - Present
post #1 of 5 (permalink) Old Aug 5th, 2014, 12:22 PM Thread Starter
Local Time: 06:26 AM
United-Kingdom Engine misfire on acceleration
Hi, I've been having an intermittant issue where my cooper s clubman seems to misfire under heavy acceleration. It can happen when moving up the gears or when in 6th and you accelerate (for example, on the motorway)
There appears to be a misfire and a load of smoke blows from the exhaust. It then clears and is ok.
A little embarresing when trying to pull away from a tail-gater
Has anyone else had / aware of this issue ?
Is it something silly like a bad coil pack or the dreaded timing chain tensioner
Any advice is greatly appriciated
J Murf is offline
post #2 of 5 (permalink) Old Aug 27th, 2014, 01:24 PM
Local Time: 07:26 AM
South Africa
Hi. I also have a problem with my mini cooper clubman 2008 clubman. Its misfiring when I am idling..but when I take off...its fine....what could be the problem?
fattyrama is offline
post #3 of 5 (permalink) Old Aug 27th, 2014, 09:00 PM
Damned
Restyle's Avatar
Local Time: 05:26 AM
Quoted: 4 Post(s)
United Kingdom Male View Restyle's Hyper Blue & White 1st Gen MINI Cooper S Profile View Restyle's Classified Ads
1st thing I'd try is simply changing the spark plugs, this cured a similar issue on mine - & as they (only) cost around 20 -, even if its something else at fault like the ignition coil, the car will always benefit from new plugs
Restyle is offline
post #4 of 5 (permalink) Old Jul 31st, 2015, 08:05 AM Thread Starter
Mine does the exact same even after a service with new spark plugs. Did you ever sort it ?
J Murf is offline
post #5 of 5 (permalink) Old Jul 31st, 2015, 11:11 AM
Netherlands Male
I had the exact same problem with my 2003 cooper s, decided to upgrade the spark plug wires and ignition coil to that of msd. solved all my problems. if the spark plugs don't solve it, I guess you could take a look at that...
Hoekie is offline
Tags: ,
Engine idle , cuts out , no acceleration shane321123 Second Generation Faults & Fixes 1 Jul 8th, 2014 03:05 PM
R56 Engine replaced; now destroys drive shafts! 696scouse Second Generation MINI Cooper S 5 Jun 30th, 2014 12:26 PM
Time Chain Tensioner failure and Engine shut down jhl2435 Second Generation Faults & Fixes 2 Mar 1st, 2014 08:45 PM
Engine revs up then down during constant acceleration JmichaelN88 Maintenance & MINI Care 2 Jan 24th, 2013 11:17 PM
BMW three-cylinder MINI engine revealed mab01uk MINI in the Media 1 Oct 9th, 2012 11:42 PM
