| MINI2 Regular | How hard is it to fit...... Anyone fitted a full aero kit to there mcsc ? if so how hard is it ? im really considering doing this myself but would like some advice on doing it. Ive seen some people on Mini2 have fitted the kit to the hard top but i belive the covertible is slightly different.. All help apreciated Adam |
| TYPE R GT VTEC POWERED | There is a PDF on MINI Cooper Accessories, MINI Cooper Parts, Racing and Performance & its a doddle to do |
| Clubman Convert Join Date: Jan 2004 Location: Hampshire Local Time: 10:39 AM
Online | Hi Adam, The Aero front bumper fits in exactly the same way as the hardtop, and the rear bumper has only minor differences in attach points. Both are very straightforward though. Only thing to consider on the rear bumber is the PDC sensors. The inner part of the sensor (the sensor body) unclips from the inside of the bumper, while the outer trim ring pulls out from the outside (once the sensor body has been removed). The side skirts are a tad different too, but only due to the cross bracing under the car which bolts into the sills. If your car is fairly new, you should be able to remove the bracing (one side at a time) using a large Torx bit (between 55-65) and a large levered ratchet. Use some bolt release spray or WD40 to help. Failing that you can cut an insert in the skirt to fit around the bracing. Either which way you'll never tell. Any probs, give me a shout. Jon ![]() |
| MINI2 Regular Join Date: Feb 2006 Local Time: 10:39 AM
Offline | Just try not to slice your hand open with a lethal 'break-away blade' stanely knife when you're doing the skirts like i managed to do (step where trying to prise door nameplate sill up). I had to clean the blood off the car before i went to casualty for stiches- I just couldn't leave it like that , but hey thats the fun of DIY!!!![]() |
| | #6 (permalink) |
Online | Indeed.... I went with the screwdriver and pull method though - word of warning, treat the sill plates like a knife, the edges are often razor sharp (as I also found out). I was wearing thick latex gloves, and they sliced straight through those and into my hand ![]() ![]() |
| | #8 (permalink) |
| MINI2 Regular | Thanks !!! Hi, Thanks very much for this info !!! im going to do it myself then all positive feedback which is what i was hoping for !!! I will take pics as i do it so others can see how its done or should i say not to do it LOL !! Thanks Again Adam ![]() |
| Help--- How hard is it to fit the Dinan CAI?? | JohnCopS | Engine & Drivetrain Tuning | 4 | Apr 18th, 2006 09:45 PM |
| How hard is it to fit bonnet stripes yourself ? | DCM | Exterior | 9 | Sep 2nd, 2004 07:56 AM |
| 4 spotlights - where to buy and how hard to fit? | Chris A | Exterior | 1 | Jan 16th, 2004 10:34 AM |
| JCWs Kit Factory Fit or Dealer fit what route would you go if you had a choice.!! | dinger | MINI Cooper S | 13 | Jul 17th, 2003 07:12 PM |
| JCWs Kit Factory Fit or Dealer Fit | dinger | MINI Cooper S | 0 | Jul 16th, 2003 07:31 AM |
