| Tags: boot |
| MINI2 Newbie Join Date: Aug 2007 Location: New Hampshire Local Time: 06:59 AM
Offline | Help Hi All- I have been exploring MINI 2 for over a year, but this is my first post.. I purchased my MINI last July and I have some questions and I figured this would be the place to get some answers.. Any advice is appreciated... Since I purchased my MINI last year, I have noticed infrequently that the boot light keeps coming on- eventhough I know the boot is closed. I thought that maybe the sensor was dirty, but as the summer has progressed, the light just seems to be on all the time, especially when going up hill, but then will magically turn itself off.. I have also noticed recently a grease stain on the bottom of the boot cover (on the outside).. there are 2 machined holes on the inside where the grease seems to be coming from.. Is this normal or is my MINI falling apart on me?? ![]() thanks- Cate |
![]() MINI2 Master Join Date: Jul 2006 Location: Essex Local Time: 11:59 AM
Offline | I have the same thing sometimes although it hasn't done it for a while, apparently it is water getting in through a gap somewhere and creating a short circuit . My boot has actually opened by itself before and it used to always open when I turned my headlights off. ![]() ![]() ![]() ![]() ![]() |
| Auntie Wiz Join Date: Sep 2006 Location: eastbourne Local Time: 11:59 AM
Offline | Cate, Boot warning light, Mine only started to do this last week...4 times in one week! It goes off when I turn the key in the ignition. Will speak to my dealer on Wednesday and let you know. The little hole I cant help with Im affraid, |
![]() Lord of The Four Rings Join Date: Nov 2002 Location: Reminiscing Local Time: 11:59 AM
Offline | The boot warning light thingy is caused by a faulty sensor which I believe needs adjusting or replacing. Get it done under warranty - I had the same problem and all is ok now. That's not a very technical answer but it may help. ![]() 170508 ![]() |
| aka Mishka | The grease you are noticing is the kosmoline(I realize that I probably misspelled it) that is used to protect the car during it's cruise across the Atlantic. It is supposed to be cleaned off when the cars are unloaded, but does have a tendency to continue to leak out of some holes and seams even after being cleaned. Check with you dealer to see what they recommend to clean it off. BTW: Welcome to MINI ownership! Improvise, adapt, and overcome. |
