| MINI2 Newbie Join Date: Sep 2004 Local Time: 02:11 PM
Offline | How does your convertible like the cold? I was wondering with temperatures struggling to hit 0 F here in the mid-west how are the convertibles holding up? Can you keep warm while motoring down the freeway? Thanks Duane |
| kltpzyxm | wouldnt know as the coldest its ever been down here in SoCal was about 47f.. I was zipping along PCH and then sunset blvd at around 2am with the top down having a blast.. couldnt feel my ears, but damn was it fun with heated seats and ear muffs you should be fine i think.. |
![]() I can't spell | I am having some issues with the heat in my convert...I think there might be something wrong with it, cause it is only warm if I have the dash vents on blowing at full force. I don't think this is typical though. I have to have it looked at. ![]() RIP Boo |
| | #7 (permalink) |
| MINI2 Senior | Just got back in town where my MINI sat at the outside lot at the airport withtemps dipping into the low teens every night. When I got to pick her up, it was 21 deg. The car heated up fine and there were no issues with starting (aside from my guilt about making her sleep outside in such frigid conditions ). |
| | #8 (permalink) |
| MINI2 Senior Join Date: Jan 2004 Location: Northern Virginia Local Time: 09:11 AM
Offline | not bad It was 18 degrees after work today. Car heated up well, my drive home from work is about 10 minutes. About 5 minutes into the drive my car was warm. Heated seats are great. Though it always seems odd to me they can heat up before the air in the car. I can barely tell the difference being in this car in the cold as oppose to my last one. |
| | #10 (permalink) |
| Only Unbalanced | Mine doesn't heat up so well. I tend to drive with the top down. This morning it was 9F, which I think is about -11C or so. But, it's not a bad problem because I tend to bundle, and the cold air doesn't really blow in. Contrary to what Madison MINI was telling me in October, there IS air blowing in from between the seats. It sometimes nips my upper thighs. But, the seat heater works, the air blows nicely on 2 and 3, and my gloves work well. But, I almost lost feeling in my thumb using my bare hand to adjust something in the cab. d PS, my neighbor at work came in yesterday and asked if I drove with the top down (I parked it that way) I said yes, and he said "then it WAS you. There are people talking about this Orange Cab up and down Rte 17 that drives with the top down in the snow!" |
| | #11 (permalink) |
| MINI2 Regular Join Date: May 2004 Location: Andover, Hants Local Time: 03:11 PM
Offline | Ducttape - I'm with you - top down whatever, although it hasn't got as extremely cold here as where you are. Found a neat (or mad) way of reducing the draft in the cabin though - I've tied the sleeves of a sweater around the headrests of the front seats and let the 'body' of it hang between them - cuts down a lot of the draft, especially at higher speeds (80+). Still a bit of cold air coming under the seats and between the seat and the door though but the cabin is retaining a lot more of the heat the vents are putting out. Still struggling to find the best setting for the vent control though - set to the feet/face position neather seem to pump out much heat, even with the blower on full. But they sure give enough out to heat the car quickly on those occaisions the roof is up. Black Cooper Cabrio Chili; 17" Bullets; Manual a/c; Xenons; Heated Seats; MFSW; Vis pk; Heated Mirrors; TLC; Alpine 9835R + IPod; |
| | #12 (permalink) |
| Only Unbalanced | Rich! My Man! You may have solved the problem! There is another thread where we all complain about the absurd cost of the wind deflector. You may have solved the problem! Now obviously, I'm not going to permanently use a sweater to deflect the wind (no, anything about a $500 car deserves more!), but at least the wheels are turning. Maybe something velcro'ed between the seats. Brilliant! Thank you so much! Sometimes the best solutions are the easiest (and, thank goodness, the cheapest.) d |
| | #13 (permalink) |
Offline | Why thank you! I best rush off to the patent office quick then.... I was planning to do a bit of development work when I get a good w/e and the weather is better (although they tend to be the ones where I go off driving!). I was thinking along similar lines too - some elastic, a bit of well positioned velcro and some stockings! (Or similar material... ) Want it to be easy to put in and out, I occaisionally allow people in the back, and hopefully cover the gaps under the seats and by the doors too. Needs to be easy to put in (MIni, take note with your Oragami wind deflector!) and compact enought to put in the boot.I do have one confession, I use the sweater in conjunction with the wind-deflector - you are REALLY brave (or mad) driving in your temps at speed w/o even the deflector! Black Cooper Cabrio Chili; 17" Bullets; Manual a/c; Xenons; Heated Seats; MFSW; Vis pk; Heated Mirrors; TLC; Alpine 9835R + IPod; |
| | #15 (permalink) |
Offline | Sounds like a plan - I am thinking along the same lines - perhaps elasticated 'pockets' to put the headrests into - but then taking the fabric right to the sides of the car to try and prevent the draft down the side too - good old velcro huh? The idea of the 'stocking' material was to still give visibility - similar to the current wind defelector. Toying with the idea of it also filling the gab between the headrests as well as the body of the seats. Madder than a mad thing on mad day you are.... Black Cooper Cabrio Chili; 17" Bullets; Manual a/c; Xenons; Heated Seats; MFSW; Vis pk; Heated Mirrors; TLC; Alpine 9835R + IPod; |
| | #18 (permalink) |
| MINI2 Regular Join Date: May 2002 Location: Telford, Shropshire Local Time: 02:11 PM
Offline | I actually had the wind deflector on my spec when I ordered my cabrio', but on reflection decided it was a bit expensive and cancelled it. Thought I would have a go at designing an alternative, something that would fit, as you have all suggested, behind the rollover hoops. Will let you know how I get on - when I get the car at beginning of March. Black & Chrome MCC. It's a MINI Jim - but not as we know it! |
| | #20 (permalink) |
| MINI2 Newbie Join Date: Jul 2004 Location: Munich Local Time: 04:11 PM
Offline | MINI Tested at 0F Hi there! Recently we had about 0F here in Munich and the MINI runs perfect. Sure the leather seats are freezing when you sit down at first but the seat heating is brilliant. To accelerate the heating, I switch off the fresh air supply, so that the fan reuses the cabin air. My impression was, that this really makes a difference. I keep the fresh air out until the windows start to get steamy but by then the air is cabin air already so warm, that it's fine to let the fresh air in. By the way, went into the alps after christmas and didn't have the slightest problems getting up the snowy mountain side and reactivating the car after a one week standstill at an temperature between -5 and 10F. Thanks Ducttape, your idea with the sweater sounds brilliant! Even with a wind stopper in the back, I had a slight cold right arm, as wind brushes between the seats. Enjoy the wonderful winter weather! you MINI-maniac, The Jester |
| ProMini Cold Air Intake VS Alta Cold Air Intake??? | SS Mini | Engine & Drivetrain Tuning | 5 | Dec 13th, 2005 12:48 AM |
| Cold, cold cold (frozen gearbox problem) | MINIHAHAHA | Faults & Fixes | 3 | Jan 21st, 2003 01:32 AM |
