Old May 3rd, 2005, 10:22 PM   #1
mclaugh
Local Time: 11:53 PM
CD Changer Pre-wiring location?
I tried searching through the forums for an answer to this, so excuse me if I missed it.
I'm trying to find the prewiring for the CD Changer in the boot so I can hook up my new Ice Link Plus.
I tried unscrewing the one screw on the right side of the trunk, but didn't feel any wires hanging out behind there.
In general, while I can find reference to the location in a regular mini, I don't see any info for the convertible....
Thanks.
Old May 3rd, 2005, 11:18 PM   #2 (permalink)
jason2025
2003 PS MCS
jason2025's Avatar
Local Time: 08:53 PM
Send a message via MSN to jason2025
I'm sure someone else will confirm or deny this but I seem to remember that after a certain build date, they no longer were including the changer cable on new cars.
Cheers.
J\
Canada   Reply With Quote
Old May 4th, 2005, 12:51 PM   #3 (permalink)
jbian
Local Time: 03:53 AM
If you check behind the panel at the top right behind the rear seat you will find a bunch of wires taped together. Within that bunch are the 2 connectors you are looking for. I have a February build 2005 convertible and that is where I found them.
Old May 6th, 2005, 01:58 PM   #4 (permalink)
Trophy160
Trophy160's Avatar
Local Time: 04:53 AM
Send a message via MSN to Trophy160
Hi,
Is the bracket for installing the changer in a Convertible any different to the
one in a hardtop ?
Paul;
England Male View Trophy160's Chili Red & White 2nd Gen MINI Cooper Profile   Reply With Quote
Old May 6th, 2005, 04:06 PM   #5 (permalink)
gaminicool
What's this red line for?
gaminicool's Avatar
Local Time: 10:53 PM
Quote: Originally Posted by Trophy160
Hi,
one in a hardtop ?
Paul;
Yes it is different. It does have its own part number - I don't know it off hand tho
United States Male View gaminicool's Hyper Blue & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old May 8th, 2005, 03:58 PM   #6 (permalink)
Trophy160
Trophy160's Avatar
Hi,
I've looked inside both of the rear panels, i guess that they are the carpety removable
bits, and I can't find the cables for the changer.
Could it be one of those things that altough free needed to be added to the
order by the dealer ?
On the upside I did find a accessory socket in the boot that I didn't know about
Paul;
Old May 8th, 2005, 08:44 PM   #7 (permalink)
JPit
My cables were located just below the seat belt retractor for the rear right passenger. Easier to get to from the passenger seat rather from the boot.
Old May 9th, 2005, 06:39 PM   #8 (permalink)
langzhu
United-Kingdom
Cheers.
J\
I thought that it was otherway round: CD changer prep became standard after certain date.
Old May 9th, 2005, 06:41 PM   #9 (permalink)
langzhu
United-Kingdom
I found two very small black connectors in the mentioned location. Are they the ones for the CD changer?
Old May 9th, 2005, 07:36 PM   #10 (permalink)
Trophy160
Trophy160's Avatar
Starting to feel a bit thick on this one as I haven't found them yet !
Could someone post a picture
Paul;
Old May 9th, 2005, 10:04 PM   #11 (permalink)
langzhu
Paul;
If you remove the right-hand side carpety panel just behind the back of the rear seat - near the screw, you should see the setbelt retracter. There is a bunch of wires just underneath it wrapped by some paper tape (white in my case). The connecters are rapped inside it. The connecters are smaller than the little finger. You need to break the tape to get to them. Hope that this helps.
Lang
Old Jun 30th, 2005, 05:54 AM   #12 (permalink)
jakearama
jakearama's Avatar
Canada Please post a photo! Looked for 2 hours!!!
I looked for the cd prep for about 2 hours (if not longer) tonight (the 1st night with my new MCSC) but wasn't able to find them at all. Removed all of the carpet from the boot on the passenger side but no luck and they weren't wrapped in tape under the seat belt retractor or in the access panel at the top. Needless to say, I'm very frustrated as this was such an easy task with my 2002 MCS. If anyone could post a photo, showing exactly where they found the CD prep it would be very greatly appreciated. Also if you happened to find the CD prep in a location other than the two mentioned above, could you please indicate that.
Many thanks,
Jakearama.
'05 All Black MCS Convertible cordoba beige leather, premium and sport package, LSD
Canada View jakearama's Solid Black & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old Jun 30th, 2005, 06:10 AM   #13 (permalink)
Rakey
Four Candles?
Rakey's Avatar
Thanks.
if your just trying to fit an Ice link you won't need to find the connection in the boot, you just un-hook the connector on the Head Unit and the ice link replaces it there
As for everyone else hunting, if some does find its location in the boot, please post a photo for everyone else
Old Jun 30th, 2005, 12:36 PM   #14 (permalink)
Trophy160
Trophy160's Avatar
Hi,
The only way to get at the CD changer cable is to remove the whole piece of carpet
from the side of the boot of the car. You can't get to it by removing the carpet flap in the
back corner of the boot. Once you have removed the carpet you will find the cable near
to the rear seatbelt holder. You can't find the cable by having a fish arround behind
the carpet as it is too far up.
Hope this helps
Paul;
Old Jun 30th, 2005, 03:47 PM   #15 (permalink)
jakearama
jakearama's Avatar
Canada Is the CD prep there with the HK system?
Ok, here's my new question. I did remove all of the carpeting from the back of the convertible on the passenger side and did not find any CD prep (either by the seat belt retractor or anywhere else). Thus, my question is that I have the HK sound system so does this CD Prep even exist with the HK system and, if so, can anyone at all confirm they have found the CD prep in an HK equipped car and confirm the location. I would love to see a pic of the connector as well. Someone mentioned it was taped up in a wire bundle by the seat belt retractor but I felt the wires in this bundle and there's no way that those two connectors would fit within that wire bundle (it simply wasn't thick enough). Please post a photo...anyone??
Jakearama.
Old Oct 7th, 2005, 10:04 PM   #16 (permalink)
Ellums
Ellums's Avatar
Any help on getting the panels out? I am trying to find the CD connector as well, but hesitate to just yank on my carperting. Anyone know where fasteners are located that are not visible?
Old Oct 8th, 2005, 04:58 AM   #17 (permalink)
goofytruax
Sith MINI is OUTSTANDING!
goofytruax's Avatar
The carpet liner on the sides has a half to one inch lip that drops behind the floor panel. I dropped the seats down and lifted it while sitting on the seat back. The only pic I have are of the install of my ice link up front. none of the harness
United States Male View goofytruax's Chili Red & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old Jan 7th, 2006, 08:16 PM   #18 (permalink)
HarryHBMCC
HarryHBMCC's Avatar
Is the screw holding the right-side boot panelling supposed to undo? Is there some trick? I turn it to the left and keep turning and turning and it never seems to loosen.
I have an 05/05 build MC Convertible with HK stereo. Will there be any pre-wiring in there anyways? I want to use my Blitzsafe AUX adapter with it but I'm beginning to wonder if I shouldn't just spend a few bucks and get the proper MINI AUX adapter instead.
Harry
Canada View HarryHBMCC's Hyper Blue & Dark Blue 1st Gen MINI Cooper Convertible Profile   Reply With Quote
Old Jan 11th, 2006, 12:13 AM   #19 (permalink)
goofytruax
goofytruax's Avatar
It is not a screw but an anchor. What looks like a screw head pushes into the anchor and expans the butterfly part. To get it out us a flat head or your fingernail to push it out while turning it.
Old Jan 11th, 2006, 11:28 PM   #20 (permalink)
HarryHBMCC
HarryHBMCC's Avatar
Thanks, that helped me get the carpet panel off but like Jakearama, I don't see any CD Changer wires there, just thick wires that seems to be attached to the taillight cluster as the same colours are attached where the bulb change 'hatch' is located. So it looks like I'm out of luck with my Blitzsafe and will have to get a proper AUX connector. Thanks for the help though!
Harry
CD Changer Wire location minifridge Maintenance & MINI Care 6 Sep 27th, 2007 09:13 AM
new location for CD changer Hat 2nd Gen Interior & Ice 13 Aug 24th, 2006 07:18 AM
H/K retrofit wiring location HELP snoopy Interior & Ice 0 Sep 10th, 2005 01:36 AM
CD-Changer prep location? MarkW19 Interior & Ice 15 Aug 5th, 2003 07:49 PM
CD Changer location olerud400 Interior & Ice 2 Jan 15th, 2003 11:03 PM
