Performance Torque
Old May 23rd, 2005, 05:04 PM   #1
bEATLEpAUL
bEATLEpAUL's Avatar
Local Time: 07:01 AM
Unhappy Electric roof 'sticks' on comfort option ?
Does anybody else have the same problem as me ? sometimes when I open the roof using the 'comfort' remote key option the following happens:
The sunroof and windows open as normal;
the roof unhinges;
and then nothing !!
a red right flashes on the 'roof' button, and I cannot open / close the roof no matter what method I use (Key / Roof button / Central lock tag). The car cannot be driven as the roof is nether open or closed, just unhinged. I have checked the parcel shelf to ensure the sensor in the boot are not affected.
Then after several minutes the roof operates as normal ??
This has happened around six or seven times, any advice (the comfort option is very erratic and sometimes decides not to work at all.
Old May 23rd, 2005, 07:56 PM   #2 (permalink)
marko14u
This has happened to me several times. I don't know why it happens - the button is still fully depressed but yet the roof stops going down. I think once the sunroof opens you have to let the button go and press it again, but still it fails to work. Anyone got advice on this matter?
United Kingdom Male View marko14u's Cool Blue & Black 1st Gen MINI One Convertible Profile   Reply With Quote
Old May 23rd, 2005, 09:55 PM   #3 (permalink)
barbaloot
barbaloot's Avatar
Local Time: 11:01 PM
Send a message via AIM to barbaloot
I have this problem. But I think it has to do with the car and the key losing their connection. Once it loses it you can't restart it. You have to get in the car and use the regular button.
United States View barbaloot's Cool Blue & Dark Blue 1st Gen MINI Cooper Convertible Profile   Reply With Quote
Old May 23rd, 2005, 11:20 PM   #4 (permalink)
bEATLEpAUL
bEATLEpAUL's Avatar
UPDATE : No I have placed the key in the ignition, started the car, and still the roof will not open or close, it just stays 'unhinged'. When I leave it for several minutes it springs back into action, I can then drive topless ?!?
Old May 24th, 2005, 08:11 PM   #5 (permalink)
Lil Blue
Autobahn Burner
Lil Blue's Avatar
Micro Switches
Have your dealer check and replace the micro switches that sense the rear package tray. There have been others who have had similar problems with malfunctioning switches causing the roof to falsely sense that the package tray is out of position. It could also be loose wiring between the switch and the wiring harness somewhere.
Good luck,
Steve
United States View Lil Blue's Hyper Blue & Dark Blue 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old May 24th, 2005, 08:12 PM   #6 (permalink)
marko14u
As mebtioned before the comfort mode usually tends not to work - but if i use the button inside the car, then the roof always opens. Go to your dealer ASAP and see if they can rectify the problem
Old May 29th, 2005, 01:24 AM   #7 (permalink)
Cherry2005
Cherry2005's Avatar
Local Time: 06:01 AM
I thought it was just my MINI behaving badly!
Sometimes she doesn't cooperate, and I must really coax the roof down using the key. I don't have a problem with the sunroof portion, but opening the roof doesn't always work the first time, so I'll press the alarm/lock and start again and the roof will open.
I've never had a problem with it using the button inside the car.
United States View Cherry2005's Chili Red & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Electric Blue Option and Aero Kit on R56??? monkeynuts 2nd Gen MINI Cooper S 8 Oct 20th, 2006 10:14 AM
electric folding roof damiond Exterior 19 May 16th, 2006 07:44 AM
electric roof fifi_li General Discussion 26 Nov 6th, 2005 06:00 PM
What Roof Graphic on Electric Blue/White Roof jasonhendry Exterior 11 Sep 10th, 2004 08:18 AM
proof at last comfort opening is an option Silver Surfer General Discussion 10 May 5th, 2002 02:51 PM
