| Clubman Rules! Join Date: Mar 2007 Location: Doncaster (ish) Local Time: 11:57 AM
Offline | windscreen disaster... help needed Ok so my other half was driving down the M180 today when a stone smacked him on the windscreen - 1 x cracked windscreen... annoying enough but the windscreen insurance will cover that. Sadly the stone has also damaged the black side arm that runs down the edge of the windscreen.(its chipped a chunk out) Does anyone know if these are replacemnet parts easily available and what kind of cost? - clearly dont want to make full insurance claim as policy will rocket.... So upsetting as car is 12 days old.... |
| MINI2 Sponsor Join Date: Mar 2006 Local Time: 11:57 AM
Offline | they are easilly replaced about just over £20 each -held in by a few screws and pop studs worth replacing the rubber gasket beneath it too if you have an early car-the windscreen people usually break them anyway or they fall off shortly after the screen change! |
Offline | Have seen the ones on your site A PILLER COVER (black trim) - will these fit the cooper D? Are they easy to fit or is it a job for dealership |
| | #7 (permalink) |
| MINI2 Newbie Join Date: Sep 2003 Location: Seaford Local Time: 10:57 AM
Offline | I know autoglass replace both side trims when the replaced my windscreen when it cracked, they said it was easier as they genearlly break when the replace the screen anyway and the insurance pays for them as well |
| | #9 (permalink) |
| GP 0380 | The RAC only replaced one of the A pillar trims for me, as they only cracked one when putting windscreen in, but they also cracked the corner piece, and took a bit out of the seal that runs along bottom of windscreen. So anyway, about a month later the same A pillar trim cracked, so I assume their replacement was put on right. Tip, dont go to RAC, local windscreen company came to replace the screen second time it cracked, and they showed me all the bits the RAC had broken! Also RAC didnt use a good windscreen, used a cheapo RAC alternative. Which was rubbish. As if it isnt bad enough the R53 had such a curve in the windscreen it is a fair bit thinner than other cars, hence the crack so easy. Cost me a small fortune to replace bottom seal, A pillar trim, and the corner piece, over £100 this time round. ![]() |
| Advice Needed: New Windscreen | burns863 | Exterior | 17 | Jan 26th, 2007 06:53 AM |
| A MINI disaster! | bluesmagoos | General Discussion | 4 | Nov 23rd, 2004 08:03 PM |
| Spec Disaster! | Simon James | General Discussion | 63 | Sep 5th, 2003 04:36 PM |
| Disaster Struck!!! | bishtelli | Exterior | 4 | Sep 12th, 2002 04:26 PM |
