Visit Out Motoring!
Tags: ,
Old Aug 1st, 2007, 07:09 PM   #1
trapper
Local Time: 09:41 PM
England Rattle from O/S Engine on acceleration
My wife has now collected her Cooper D and she really likes it, its a great car.
There is an annoying rattle or vibration on acceleration which can also be heard when you rev the engine slightly but not as noticable as it is when actually driving. The rattle seems be coming from the O/S of the engine area.
She phoned the dealer today who said it was 'normal' but to pop in and they would 'have a look'
If it is 'normal' I am sure the forum members will have come across it and can let us know what the cause is.
Any ideas?
Old Aug 1st, 2007, 07:43 PM   #2 (permalink)
Steffi
SooperDooper
Steffi's Avatar
Local Time: 10:41 PM
Send a message via Skype™ to Steffi
Question
Having just done a 2700 mile run to Poland and back in my new Dooper, with flat out running for miles and coping with the awful Polish roads, on the way back, the Dooper started to rattle. Sounded like the exhaust manifold... but on inspection was in fact the air intake hose. The vibration and noise made me think something awful had happend. Take a look at the air intake, about half way along its length it is attached to the block by a lug where the rubber mount pushes onto. This comes loose and will need a new mount. There is a two week wait while they back order from Germany. As I said the vibration and noise is way beyond what you would think for just a hose coming loose. Hope this is it and helps.
Steffi
Old Aug 2nd, 2007, 08:44 PM   #3 (permalink)
trapper
Thanks Steffi.
I will check on your suggestion but its not a very loud rattle and the cars done less than 1000 miles, there's not much room to get a good look in either!
Old Aug 4th, 2007, 04:45 PM   #4 (permalink)
trapper
Took it into the dealers today, on the way I noticed another rattle from the dashboard!
Anyway the workshop agreed that it had two rattles, the dashboard and engine, as soon as we get a chance we will have to book it in for them to rectify the problems.
Old Aug 13th, 2007, 06:58 PM   #5 (permalink)
wolfie26
Hi - can anyone help ???
I have had my 56 Cooper now since December 06 and this last month it has developed the most annoying vibration cum rattle in the dashboard area. I have tried everything (holding the mirror as one person suggested, checking the vents another, looking in the door pockets for loose bits!!)
The car went in to the garage and b****r me if the car didn't perform. Bring it in when it does it again - they said - we took it for run and we can't find it!!
I have been in twice now and I leave the car running on the forecourt and guess what - yes you guessed the little b****r stops.
Try recording the noise on the mobile phone was another idea!!
Any ideas fellow mini lovers or am i destined to go stark raving bonkers.
Old Aug 14th, 2007, 06:23 PM   #6 (permalink)
Steffi
SooperDooper
Steffi's Avatar
Angry
Ours had the new intake hose replaced today to stop the vibration. Fell off one mile up the road. Now held on with bag ties. The mechanic is going to e-mail Mini as he feels this could be a design fault. The air intake hose is attached by a rubber part being pushed onto a metal lug about halfway along its length. This seems to work its way loose and fall off. It also causes the open end at the front right of the car (looking at it) to vibrate against its metal surround. It sounds like a vibration behind the dash and is very annoying. I am off to B&Q tomorrow, or WHSmith to get some velcro. Hopefully this will isolate the parts causing the noise. As I said in the previous note above, the noise is out of proportion to what the problem is, it also sounds as though it is in the dash or the bulk head area.
Steffi
Old Aug 14th, 2007, 07:09 PM   #7 (permalink)
trapper
Well the noise has gone Scotthall's Borehamwood took the car in and found some 'loose pipes' (That's what my wife said) anyway these caused both rattles as once they re-attached the pipes both rattles went.
Result....
Old Aug 14th, 2007, 07:32 PM   #8 (permalink)
john_james
john_james's Avatar
Ihad same noise until I had to go to dealer about somthing unrelated they said to bring the car in as there was a "Recall" and they had to change some bolts and the car had to be cold!,when i picked car up 2 hours later it was like driving a different car noises all gone,from what i saw and heard they changed the bolts between cat convertor and turbo
03 MCS - rattle/tapping under hard acceleration Alex5 Faults & Fixes 14 Feb 14th, 2007 11:02 AM
Rattle upon hard(ish) acceleration powderhounduk Faults & Fixes 0 Dec 12th, 2005 08:10 PM
Rattle on acceleration - Curious Malky Faults & Fixes 7 Feb 23rd, 2004 08:09 PM
acceleration rattle ?? happy_0128 Faults & Fixes 1 Jul 30th, 2003 06:49 AM
Noisy engine on acceleration niall Faults & Fixes 0 Feb 21st, 2003 09:01 PM
