Tags: ,
Old Feb 3rd, 2008, 03:17 PM   #1
Wind Diesel
Living in my MINI dream !
Wind Diesel's Avatar
Local Time: 01:02 PM
Bleeding of the EGR valve ?
Today i tried to bleed of the EGR valve to remove later on problems with buth after only 5 miles of driving, i got the engine management warning light' as expected.
Can't find ANY information about HOW TO bleed of the EGR valve on this engine, but if anyone can give any information about how to do it with succes' please ... i'm waiting.
Heggelund&Wind Photographix-Mini Dooper R56 LiB/W - My MINI Blog
Denmark Male View Wind Diesel's Lightning Blue & White 2nd Gen MINI Cooper Diesel Profile   Reply With Quote
Old Feb 4th, 2008, 07:11 PM   #2 (permalink)
Hickster
E's H2B
Hickster's Avatar
Local Time: 12:02 PM
Send a message via MSN to Hickster Send a message via Yahoo to Hickster
Not sure if that is such a good idea. I've heard you can create blockages in inlet manifold if you disconnect the EGR valve. It's not something I'd mess with, and I wouldn't be surprised of it's inspected as part of the service routine.
D-lite-full
United Kingdom Male View Hickster's Pepper White & Black 2nd Gen MINI Cooper Diesel Profile   Reply With Quote
Old Feb 4th, 2008, 07:38 PM   #3 (permalink)
Wind Diesel
To disable the EGR is the only right thing to do !
I did it on my 2.0 8V HDI' engine, and it worked PERFECT, and gained 2 miles pr. liter diesel, as i don't have to process the smoke from the engine twice'....
Perfect compustion is made from fuel and air, not exhaust gasses !
Old Feb 4th, 2008, 08:28 PM   #4 (permalink)
bob corbishley
I was wondering what you trying to bleed? Are you actually trying to block it off?
I wouldn't do that because the engine management on a car with a DPF is extremely sensitive. If you start making modifications and trying to trick the ECU then the DPF could heat up out of control during a regen cycle leading to a fire (without EGR the exhaust will be hotter and contain more NOx).
Also DPFs are expensive and shouldn't need changing until 90,000miles (I bet thats why XL TLC runs out at 80,000).
United Kingdom View bob corbishley's Chili Red & White 2nd Gen MINI Cooper Diesel Profile   Reply With Quote
Old Feb 4th, 2008, 08:31 PM   #5 (permalink)
Wind Diesel
Yes, the plan was to block it off 100% !
Old Feb 4th, 2008, 08:38 PM   #6 (permalink)
bob corbishley
As much as it is an easy way to make more power it will screw up the emissions control systems. This is the problem with modern diesels. The cleaner they get the more fuel they consume. All the crap in the exhaust pipe is just restricting the engine.
Its a bit early to be tuning the dooper and considering that BMW themselves had to recall some early Doopers to remap to reduce the risk of DPF fires it not something I'd like to try.
Bleeding brakes - advice please s33gav Wheels, Tyres & Brakes 5 Oct 3rd, 2007 04:52 PM
My Bleeding heart!! kars General Discussion 45 Mar 12th, 2005 10:13 PM
My Mini is bleeding! :( Jones Faults & Fixes 6 Mar 2nd, 2004 09:29 PM
Brake bleeding help needed Kita Maintenance & MINI Care 3 Feb 8th, 2003 10:04 PM
