Auto Stop Start newbie - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Cooper Diesel
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
Old Jan 29th, 2012, 03:41 PM
Local Time: 01:05 AM
Hi all, i know i'm a noob, however i need to know about his stop start nonsense bought my dooper friday and works a treat love it! however this stop start thing has got me confused .....
basically pull up to the lights it stops and second later starts again, and i assume it needs to be warm, but then the engine doesn't cut out when it's warm ... very odd
btw it's a 08 plate
Regards,
Richard
Old Jan 29th, 2012, 08:42 PM
Send a message via MSN to ScoobyChris
The car decides when to switch off the engine (based on the charge of the battery, load, outside temperature, etc). When everything's working correctly, it'll switch off the engine when you pop it in neutral (with the clutch up) and then restart when you depress the clutch to select 1st gear. For longer stops, it may start up after a while before touching the clutch, especially if you have things like air con on drawing power.
If it's not doing that, it might be worth getting it checked out...
Chris
Auto stop start Osclix Second Generation MINI Tuning 4 Oct 29th, 2011 09:00 AM
Auto Stop/Start - Opinions? spongebob General Discussion 3 May 20th, 2010 10:14 PM
Auto Stop/Start symia32 Second Generation Faults & Fixes 12 Apr 4th, 2009 02:24 PM
JCW Kit and auto stop start Johnnybass38 Second Generation Works 10 Oct 16th, 2008 12:00 PM
Auto Start/Stop Tobes Second Generation Faults & Fixes 5 Jul 18th, 2008 01:32 PM
