2007 copper clubman diesel low mpg & flat spot - Page 4 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Cooper Diesel
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
  #46 (permalink)
Old Jan 2nd, 2013, 08:14 PM
Local Time: 06:52 AM
Right then got second new maf this time pierburg and done a quick test drive and mpg was going up and no flat spots will see how it goes this week
  #47 (permalink)
Old Jan 2nd, 2013, 09:40 PM
Dixy72's Avatar
Cracking result I'll keep my fingers crossed, I disconnected mine but couldnt get out for a run, where did you source your new maf from and £££'s do I need deep pockets:-(
  #48 (permalink)
Old Jan 3rd, 2013, 05:58 AM
Hi got the pierburg one from eurocarparts they had 22% off so was down to 96£
  #49 (permalink)
Old Jan 3rd, 2013, 08:11 AM
Dixy72's Avatar
yes thats alot better must go and have a look, cheers :-)
keep us updated too ;-)
  #50 (permalink)
Old Jan 5th, 2013, 11:46 AM
Did ours run differently with the maf unplugged?
  #51 (permalink)
Old Jan 5th, 2013, 06:58 PM
Local Time: 08:52 AM
Luxembourg Male
Off the top of my head, I recall a price of about 190 British pounds for the hot film MAF in the Cooper D.
  #52 (permalink)
Old Jan 5th, 2013, 07:31 PM
The pierburg one is running perfectly at the moment although my wife has been off this week so only a few miles done
  #53 (permalink)
Old Jan 5th, 2013, 09:04 PM
Dixy72's Avatar
yeah it did run but I got am elm which I was expecting :-) put back on and its still there :-/
  #54 (permalink)
Old Jan 5th, 2013, 10:35 PM
Male View arbi12's Classified Ads
maf sensors
surely if maf sensor was bust car would throw up a fault code, should scanner not have picked this up in live data.
dpf another french invention from pug/cit
  #55 (permalink)
Old Jan 6th, 2013, 09:07 AM
Dixy72's Avatar
I have had my scanner connected whilst driving and no codes came up, you dont get a definate fault with it as the data same to flow without fault ?????? and on the other hand too there is not a fault code for the crankcase sensor either ??????
  #56 (permalink)
Old Jan 7th, 2013, 05:56 AM
Hi mine never threw a code either but it drove better unplugged and now it's been replaced
It did turn the eml on when unplugged but was turned off by my scanner
  #57 (permalink)
Old Jan 7th, 2013, 06:43 AM
Luxembourg Male
Just to be sure, when you unplugged the MAF on the Cooper D, you got an EML? Was it right away, or how far did you have to drive?
I unplugged my MAF and drove for at least 20km and got absolutely no warning lights....
  #58 (permalink)
Old Jan 8th, 2013, 08:46 PM
As soon as I turned the engine back on I got the eml
  #59 (permalink)
Old Jan 9th, 2013, 03:12 PM
Dixy72's Avatar
hmmmm very frustrating this I did it again without any issues, but it was a cooler night not sure if this made any difference:-/ well the wife is driving away at it just now so will leave it until the weather warms up when I will change the crankcase sensor. :-)
  #60 (permalink)
Old Jan 14th, 2013, 02:23 PM
Hi Ben, sounds like you have had a right mare with your MINI. I am in a similar situation with the DPF light and was wondering if I should get the delete + remap. Would you recommend it? Do you think the work P Torque did caused the leak between the DPF and the turbo?
