DPF Malfunctioning?? - MINI Cooper Forum
Go Back   MINI Cooper Forum > Model Specific MINI Forums > MINI Cooper Diesel
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
DPF additive tank.. Where? jonny392 Second Generation Faults & Fixes 4 Mar 10th, 2014 10:46 PM
DPF Blockage, remap?? Porn_Star19 Second Generation Faults & Fixes 3 Nov 20th, 2012 08:38 PM
Cooper D DPF Regeneration Tabintab MINI Countryman 2 Oct 23rd, 2012 08:43 PM
Old Dec 16th, 2013, 02:58 PM
Local Time: 09:52 PM
Exclamation DPF Malfunctioning??
Hi all,
I'm in need of some expertise.
Last Monday my girlfriend was driving her 57 Plate Mini Cooper Diesel home from work when a warning symbol came up on the display. I checked it out when she got home and it refers to Diesel Particle Filter (DPF) Malfunctioning (CC-ID 049).
The Mini Owners manual says to drive the car over 40Mph for a period of over 5 minutes to force a regeneration. I found this to be odd as my girlfriend drives 25 miles, twice daily which is mainly dual carriageway. However, I decided to take the car out for a spin to see if I could clear the fault. I drove approximately 15 miles with the car at 2.5K revs, which didn't clear the fault, so I drove back at over 4K revs which also didn't clear it.
There are no performance or efficiency issues with the car.
The car has done 82K and fell out of it's Mini TLC XL package a couple of months ago. I didn't really want to pay main dealer prices for them to diagnose the fault, so I decided to take the car to my local approved Mini specialist.
They connected the car up to the laptop and ran the diagnostic check which failed halfway through the check with an EGR valve problem. We had this replaced costing just shy of 400. He said the EGR valve was completely blocked as were the inlet and outlet pipes. He managed to clean out the pipes. He then ran the diagnostic check again and the car passed the test. DPF blockage was showing as 0.3%. For good measure he decided to put a couple of bottles of DPF cleaner in the fuel tank just to make sure. He then took the car out and everything seemed fine.
When we picked the car up, immediately the same warning message came back, so we gave the car back to the specialist. He did another diagnostic check which passed with no faults and the DPF still reads 0.3% blocked. He tried a software update which also made no difference. It is probably worth noting that the specialist said that when he connects the laptop into the car, the warning message disappears, and then comes back when it is unplugged.
Last night I took the car out for a 60 miles round trip and kept the car at 2.5K revs for the majority of the journey and the fault still stands. The specialist has said that there isn't anything else he can think of??
Is someone able to help me with this please, it would be much appreciated.
Thanks,
Liam
Old Dec 17th, 2013, 06:34 AM
Local Time: 11:52 PM
Luxembourg Male
If the load on the DPF was too high, even if it went through a regeneration, it may need to be reset by the dealer.
Second, he should have never put the DPF additive in the tank, there is already a reservoir of eolys fluid that is automatically injected into the fuel line depending on the particle filter load.
I'm not familiar with CC-ID 049, can you post some more detail on the exact error?
LAst, was there any change in performance after the EGR was cleaned?
Quote: Originally Posted by LSM1604 (original)
Hi all,
Thanks,
Liam
Old Dec 17th, 2013, 07:47 AM
Hi,
Thanks for the reply.
Could this not be reset by the specialist?
Ohh, I didn't realise there was an additive. I take it that the cleaner that he put through won't cause any damage?
CC-ID 049 is basically the BMW check control code - it just refers to the DPF Malfunction. I think it is just a code that matches the symbol.
It is the girlfriends car, and she hasn't noticed any performance or efficiency changes. When I took the car out Sunday night, I didn't notice any obvious differences either.
Thanks,
Liam
Old Dec 18th, 2013, 07:47 AM
Luxembourg Male
From what I understand, there are two levels of errors thrown. the first can be reset if the DPF manages to regenerate. However, the second error level requires a reset by the dealer. I suppose, depending on their equipment, a specialist non-Mini mechanic could likely reset it.
The Mini uses an additive (Eolys fluid) to burn off the particulate matter trapped by the DPF. They advise in the owner's manual not to put any additional additives into the fuel. The reason being is that the regeneration cycle activates based on the DPF load and. I think what happens is that the additive gets injected into the fuel and then the ECU increases the fuel quantity in an attempt to increase the exhaust gas temperatures. The additive lowers the combustion point of the particulate matter so that, combined exhaust gas temps and additive allow the particulates to be burned off.
There is a possibility that the additive put into the tank could foul the particle filter interior, but there is no way of knowing this unless the DPF is removed and inspected.
I know that on the Peugeot forums (the engine in the Cooper D is a Peugeot engine) I've seen people state that at high mileage the DPF becomes choked with ash after many regeneration cycles and then it requires replacement.
So, either it's a simple code issue or there might be a problem with the DPF itself. The CC-ID 049 isn't all that helpful in diagnosing the issue. The car hasn't thrown any P-codes, has it?
Hi,
Thanks,
Liam
Tags: , , , ,
» Recent Threads
no tyre grip on cooper s in wet
Apr 6th, 2014 08:17 AM
Last post by Stoo Med
Today 08:53 PM
12 Replies, 579 Views
Head gasket, not always
Yesterday 10:32 PM
by Kilty
Last post by Kilty
Today 08:44 PM
2 Replies, 152 Views
Bonnet won't open
Jan 18th, 2011 06:16 PM
Last post by Kilty
Today 08:29 PM
6 Replies, 5,744 Views
New to this! No hot air in the car!
Today 03:37 PM
Last post by VictoriaDruskyte
Today 07:46 PM
3 Replies, 106 Views
Where can I buy Spare wheel carrier for r50!
Today 07:28 PM
Today 07:28 PM
0 Replies, 35 Views
How to Retrofit the Spacesaver Spare Wheel
Dec 6th, 2011 10:40 PM
by mab01uk
Today 07:04 PM
41 Replies, 28,950 Views
Fuel additive eolys 176
Jan 24th, 2012 03:20 PM
by FATT
Last post by adriancooper111
Today 06:53 PM
10 Replies, 5,586 Views
2007 Cooper D (r56) - How to look after her and what to look for when buying
Yesterday 01:10 PM
by hyvrid
Last post by MiniDeLux
Today 06:45 PM
5 Replies, 192 Views
Mysterious Oil Leak :(
Today 12:23 PM
by phoebe
Today 06:36 PM
2 Replies, 105 Views
stop start nightmare PLEASE HELP !!!!
Apr 2nd, 2014 01:06 PM
Today 06:30 PM
12 Replies, 739 Views
Today 04:34 PM
Last post by Caveman
Today 04:42 PM
1 Replies, 94 Views
Mud flap fitting
Today 12:38 PM
Last post by Angib
Today 04:21 PM
2 Replies, 101 Views
Oil Consumption Cooper Coupe
Apr 13th, 2014 08:30 PM
Last post by The Nun
Today 02:43 PM
3 Replies, 283 Views
R56 JCW Brembo Brakes on my R53
Jul 3rd, 2010 04:52 PM
Last post by brett
Today 01:27 PM
24 Replies, 15,035 Views
roof will not retract!
Nov 12th, 2007 12:18 PM
Last post by BNSW19
Today 01:20 PM
32 Replies, 14,805 Views
LED Daytime running lights - retro fit
Yesterday 06:08 PM
Last post by sailor88
Today 01:06 PM
3 Replies, 205 Views
Retrofit Auto Dimming Rear View Mirrow
Apr 14th, 2014 07:47 PM
Last post by alexcannas
Today 12:53 PM
4 Replies, 245 Views
Caravanning with a Clubman
Apr 13th, 2014 08:21 PM
Today 08:10 AM
5 Replies, 245 Views
Updating factory sat nav?
Apr 4th, 2014 05:55 PM
by Zonda_
Last post by k3fus
Today 07:42 AM
1 Replies, 241 Views
Updating the Sat nav-beginner!
Apr 8th, 2014 12:54 PM
Last post by k3fus
Today 07:39 AM
1 Replies, 219 Views
Wheel & Tire Center
