Cooper D Chain and timing belt change - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
post #1 of 4 (permalink) Old Jan 15th, 2014, 08:19 PM Thread Starter
Local Time: 01:36 PM
Hi all,
I'm a happy owner of 08 plate Clubman Diesel. As I drive a lot the car already has nearly 140.000 miles on the clock. During the another service today I've been advised by Mini Service that it is advised to change the timing belt/chain in the car. The problem is that when I've asked the questions they couldn't really say which one (as I understand 1.6 Doopers have both) and whether this is chain change or just tensioners.
Does anyone know the details?
I would stress that the car drives extremely well, has all the optional extras and if I won't have to I wouldn't like to change it. Hence my need to address my new concerns.
forwiser is offline
post #2 of 4 (permalink) Old Jan 16th, 2014, 03:58 PM
RVW
003 On a Mission
RVW's Avatar
Quoted: 1 Post(s)
United Kingdom Male View RVW's Hot Chocolate & Silver 2nd Gen MINI Cooper Diesel Clubman Profile View RVW's Classified Ads
Originally Posted by forwiser View Post
Hi all,
Best of luck. Read the thread below and you will see why.
The Clubman Register ? View topic - Diesel Clubbie - belt or chain?
RVW is offline
post #3 of 4 (permalink) Old Jan 17th, 2014, 08:22 AM
Local Time: 02:36 PM
Quoted: 1 Post(s)
Luxembourg Male
The confusion over belt vs. chain is due to differences in terminology.
Your car has an auxiliary belt (sometimes referred to as a serpentine belt) and a cam timing chain. Please refer to the following to see the differences:
Auxiliary Belt
http://www.realoem.com/bmw/showparts...39&hg=11&fg=25
Cam timing chain:
http://www.realoem.com/bmw/showparts...40&hg=11&fg=25
The auxiliary belt is subject to wear and needs to be changed for a new one. It's a sensible thing to do just like replacing your worn down brakes. I would agree that 140,000 miles is a good time to have it changed.
The diesel engine in your Mini is an interference engine, meaning that if your auxiliary belt breaks as a result of wear, the pistons will hit the valves and destroy your engine. I would strongly advise you to have it replaced as per the recommendation you have been given.
MiniDeLux is offline
post #4 of 4 (permalink) Old Jan 17th, 2014, 11:43 AM
RVW
003 On a Mission
RVW's Avatar
Quoted: 1 Post(s)
Thanks for your reply. But an auxiliary drives other parts such as alternator,water pump etc
The belt in question does not do anything else but drive the cam shafts.
Seems funny that if you go to a dealer/garage they know exactly to what you are referring. The manufacturer and designer of the vehicle do not seem to have a clue and that is worrying .
RVW is offline
Mini Cooper S R56 Timing Chain Tensioner Mini Cooper S BUSTED Second Generation Faults & Fixes 23 Sep 4th, 2015 04:24 PM
MCS Timing Chain Tensioner A18XVM First Generation Faults & Fixes 12 Jul 8th, 2015 06:39 PM
Timing Chain / SC Pulley Change? benrayner100 General Discussion 1 Apr 25th, 2013 03:53 PM
Mini Cooper Timing Chain Tensioner How To. R56 N14B16 turbo UtilityGuy Second Generation MINI Cooper S 0 Mar 6th, 2013 11:45 PM
04 Cooper S timing chain rattle chrisnieldgte2010 First Generation MINI Tuning 1 Dec 20th, 2012 12:49 PM
