Cooper D problem when driving - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
post #1 of 16 (permalink) Old Mar 30th, 2014, 10:56 PM Thread Starter
Local Time: 05:51 PM
Ireland
Smile Cooper D problem when driving
Hi all,
I recently had a problem with my cooper
D 1.6 where it started jumping (hard to describe) suddenly
as I was driving in all gears. NO warning lights on. Very noticeable to passengers in the car too. It got very bad to the point I was afraid to drive it and had
It taken to a local garage who replaced a fuel filter (I thought maybe bad diesel)
and that did seem to remedy the problem, or so I thought!
I took it to BMW who serviced it and reported all was well and no faults. However last night as I was driving on the motorway in 6th it jumped a
couple of times again. I drove in 4th the rest of the way and it was ok
and drove ok today as well.
Does anyone know what this could be from? Also why would no
fault or warning lights be on dash?
Thanks for any advice
Shell123 is offline
post #2 of 16 (permalink) Old Mar 31st, 2014, 08:06 AM
Quoted: 53 Post(s)
You mean like the engine like stops for a second, gives a jolt? does it just the once then carries on?
Had a similar thing to that on another make, that was traced to a sticking EGR valve, renewing that cured it in my case.
The Nun is offline
post #3 of 16 (permalink) Old Mar 31st, 2014, 03:14 PM
Local Time: 04:51 PM
EGR sounds plausible.
Have you replaced the turbo seal?
Even though there were no visible problems with my turbo seal, it's a lot better with the new one.
I had to keep the revs up before and it used to 'jerk' sometimes as well.
Replacing the seal has restored the low down torque and it's much smoother.
It's only 12 and 5 minutes (very easy) work, so it's a cheap option to try before you think about the more difficult and dearer EGR.
NightfireCooper is offline
post #4 of 16 (permalink) Old Apr 1st, 2014, 12:36 PM Thread Starter
Ireland
Thanks for those suggestions I'm due to bring it
back to the BMW garage tomorrow. They said they'll
have to test drive it. I've explained it happens
intermittently so they mightn't experience it at all.
I don't mean the engine cuts off I mean its like a real
rough drive like you're being jolted along
suddenly and then returns to normal.
To me the fan belt sounds funny and engine sounds noisy also
would that be connected?
Shell123 is offline
post #5 of 16 (permalink) Old Apr 1st, 2014, 02:50 PM
Quoted: 1 Post(s)
United Kingdom View den123's Classified Ads
lets us know what it was mate
den123 is offline
post #6 of 16 (permalink) Old Apr 1st, 2014, 06:25 PM Thread Starter
Ireland
[QUOTE=Shell123;3938050]Thanks for those suggestions I'm due to bring it
Shell123 is offline
post #7 of 16 (permalink) Old Apr 2nd, 2014, 07:29 AM
Quoted: 1 Post(s)
Luxembourg Male
What do you mean by "sounds funny"?
[quote=Shell123;3938322]
MiniDeLux is offline
post #8 of 16 (permalink) Old Apr 2nd, 2014, 08:37 AM Thread Starter
Ireland
I mean there is an audible ticking sound when
car is running
Shell123 is offline
post #9 of 16 (permalink) Old Apr 2nd, 2014, 11:18 AM
The car runs rougher and sounds noisier when going through a DPF regeneration cycle.
You don't get any warning lights when that is happening either.
I'm now wondering if that's what your problem was/is.
The dealer may be able to interrogate the ECU and see when cycles have been done, which may coincide with when you felt the problem.
post #10 of 16 (permalink) Old Apr 3rd, 2014, 06:40 AM
Quoted: 1 Post(s)
Luxembourg Male
Can you identify where the ticking is coming from? Is it from the drive belt area?
Is the ticking occurring all the time or at random?
post #11 of 16 (permalink) Old Apr 3rd, 2014, 09:17 AM Thread Starter
Ireland
Angry
Shell123 is offline
post #12 of 16 (permalink) Old Apr 4th, 2014, 12:06 PM Thread Starter
Ireland
Just to update: Fuel pump is being replaced
Shell123 is offline
post #13 of 16 (permalink) Old Apr 10th, 2014, 06:13 PM Thread Starter
Ireland
Problem as of yet unsolved....
Shell123 is offline
post #14 of 16 (permalink) Old Apr 10th, 2014, 06:34 PM
Quoted: 1 Post(s)
I had problem fix this week with mine. The was small hole in breather pipe to fuel all fine now
den123 is offline
post #15 of 16 (permalink) Old Apr 10th, 2014, 09:23 PM Thread Starter
Ireland
Electrical
Shell123 is offline
Learning to Drive MINIs the Way John Cooper Intended AutoGuide.com MINI News 0 Jul 26th, 2013 06:12 PM
MINI COOPER S Convertable 53plate Exhaust problem archerluke Second Generation MINI Suspension 1 Mar 31st, 2013 05:54 PM
cooper diesel problem s5sport General Discussion 2 Dec 9th, 2012 03:08 PM
2010 Mini Cooper S starting up problem Master_Yi Second Generation Faults & Fixes 2 Oct 19th, 2012 06:37 AM
