DPF Replacement - Service Procedure ... - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
post #1 of 4 (permalink) Old Jun 25th, 2014, 02:51 PM Thread Starter
Local Time: 02:58 AM
Hello all
I need to remove the DPF canister for cleaning - please, no advice around forced regen, I have tried that !
There is very little room to extract the DPF/Cat canister, and the central shield bolts are a nightmare to get at.
The front of the shield is retained by the upper diff pressure sensor and the temp sensor - if I remove these can I then wrestle the front of the shield off ?
What is the simplest procedure for removing the DPF canister for cleaning ?
Can anyone help with relevant pages from the factory service manual, or a link to show how this is done, please ?
All useful advice is most welcome.
Regards
Chopps
chopper_harris is offline
post #2 of 4 (permalink) Old Jun 26th, 2014, 09:05 AM
Quoted: 1 Post(s)
Luxembourg Male
Procedure on a Peugeot is here:
DPF Removal and Clean Guide - Peugeot Forums
No need to remove the front of the car as can do it on a Pug which has less space than the Mini.
Originally Posted by chopper_harris View Post
Hello all
Regards
Chopps
MiniDeLux is offline
post #3 of 4 (permalink) Old Jun 28th, 2014, 12:50 PM Thread Starter
Have you actually done this job ?
The Peugeot instructions are basically correct, but you cannot remove the top clamp from the turbo to the cat because the bolt head is hidden behind the shroud - the turbo/cat is pre-assembled and fitted to the engine before installation in the Cooper D
The Peugeot article is written around the 307, there is not enough room in the Cooper D to follow the posted instructions.
The diff pressure bolts are 18mm, not 17 mm.
Is there anyone who has actually done this, and not read an article on a Peugeot forum ?
Again, can anyone help with pages from the Mini workshop manual, please
post #4 of 4 (permalink) Old Jun 29th, 2014, 07:35 PM
Quoted: 1 Post(s)
Luxembourg Male
Haven't done it myself, no. The turbo/cat assembly is not pre-assembled as far as I know. I've had the turbo on my Clubman changed and the garage didn't remove the front of the car, they removed it in situ and unbolted it from the DPF/cat.
Normally the bolt faces forward so it can be accessed. Doesn't help you, I know but it's strange the way it's been installed on yours.
Service Indicator Reset DPF Eolys FATT General Discussion 0 May 30th, 2014 10:56 AM
Replacement Service Book Choppa Maintenance & MINI Care 6 May 21st, 2013 06:04 PM
Replacement Service Book Choppa First Generation Interior & Ice 0 May 21st, 2013 03:22 PM
Mini Australia service chilld Dealership Feedback 4 Sep 4th, 2012 05:29 AM
Last TLC service @41000 Oil Service or Inspection 2 Service? Aboutstu General Discussion 3 Aug 27th, 2012 03:52 PM
