Engine fan Continues to run - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
post #1 of 2 (permalink) Old Jul 10th, 2014, 02:44 AM Thread Starter
Local Time: 08:38 AM
Australia
Is this a common problem? My wife has a Mini Cooper Diesel with the BMW N47 engine. She has just 6000ks on the clock. At completely random times the engine fan will continue to run for up to five minutes after the ignition has been turned off. We took the car back to our BMW service centre and were informed that this is something to do with the regeneration of the converter that burns off carbon deposits.It was sugested that we take the car for a brisk run at high reves so that the process may be fully completed. Does this sound correct?
stephen orford is offline
post #2 of 2 (permalink) Old Jul 10th, 2014, 01:02 PM
Local Time: 11:38 PM
Quoted: 1 Post(s)
Luxembourg Male
Seems normal. The PSA diesel engine does the same thing if you shut the car off either during or shortly after a regeneration. If the car is doing a lot of stop and start city driving you will have more frequent regenerations. Their advice to take it on the highway is quite reasonable.
If your coolant level is okay and coolant temperature is also fine, I see no issue.
MiniDeLux is offline
R56 Engine replaced; now destroys drive shafts! 696scouse Second Generation MINI Cooper S 5 Jun 30th, 2014 11:26 AM
Time Chain Tensioner failure and Engine shut down jhl2435 Second Generation Faults & Fixes 2 Mar 1st, 2014 07:45 PM
2006 S Engine for a Non S 2002 mikeroth First Generation MINI Tuning 1 Dec 10th, 2013 09:59 AM
Engine cooling fan not working? bax2079 First Generation Faults & Fixes 10 Sep 18th, 2013 10:53 AM
Stage 2 Cooling fan run on, is this normal? MiniMotoR56 Second Generation Faults & Fixes 7 Jun 4th, 2013 11:00 AM
