I currently have an R56 Mini Cooper S, and have been offered an R56 Mini Cooper SD by my company as a replacement.
Is there much difference in the Mid Range acceleration speeds? I see people on these forums refer to 'published figures' but I can't find anything anywhere to compare the two...
i had a clubman S then switched to a hatch SD i really liked it but i now have switched back to an S and i prefer it. that being said on a long run i got amazing fuel economy from my SD
I've never owned an S but the thing about an SD is that it is really high-geared and, perhaps because it's my first diesel, I find I run out of revs at the bottom end of the rev range, not the top.
So for example, even the economy-minded gear change indicator won't recommend changing up into sixth gear until nearly 50mph at small throttle openings on level road. Come to a corner and I've found it disappointing how often I need to change down to maintain performance - probably as often as I had to in my previous justa (non-turbo) Cooper.
In contrast the new F56 petrol engines look to have a massively wide 'power band', so I think I'll go back to a Cooper next time.
Driving a diesel you have to change your driving habits if youre used to a petrol, revving a diesel doesnt achieve much over 2500, youre better off change up with the revs low down and use the extra torque instead to build your speed up.
Related Threads
MINI Cooper Forum
3.6M posts
159.9K members
Since 2001
