Visit Lohen!
Old Dec 3rd, 2005, 10:53 PM   #1
yroc
Local Time: 11:47 PM
Gennex replacement BOV
I was wondering around online finding different mini stuff and came across this. http://www.gennexmotorsport.com/main.php?id=140&car=1
I am not contemplating this for the sound. Rather the fact that it has max boost adjustability so essentially you can up the point where your normal valve is set at. this of course would have to be coupled with a pulley but, you would be able to run a higher boost level. Does anyone know anything else about this product or company for that matter.
Old Dec 3rd, 2005, 11:43 PM   #2 (permalink)
kapps
kapps's Avatar
1st off, BOV is not the correct term, it's a BPV (bypass valve). On the MINI the BPV allows boost to leak out when it's not needed so the supercharger generates less heat and less drag on the engine. Once the vacuum hits a certain point, the valve closes and boost is produced. The problem with the MINI valve is that the spring is pretty soft and at part throttle in the 3-4k rpm range, you might notice a surging forward and backward. This is called yo-yo and it's due to the valve opening and closing repeatedly. A stiffer spring elleviates this problem but lowers gas mileage as well since the valve is closed more often. Detroit Tuned sells a valve with a stiffer spring and you can find it on their site http://www.detroittuned.com/ . There's no difference in boost levels between different bypass valves (if they are adjusted properly), only in how soon they close and allow boost.
United States View kapps's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 5th, 2005, 01:58 AM   #3 (permalink)
yroc
OK thank u for the correction; however is it not true that max boost is reached around 3500 rpm or so? I was under the impresion that once the sc produced the designated boost the valve would bleed to allow the boost to then stay constant as the rpm's rose. If it is not the valve, than what is it that determines the max boost?
Forge BOV adapter MCS 07 lalaboi 2nd Gen Engine & Drivetrain Tuning 20 Jun 17th, 2008 07:13 PM
R56 BOV Location? HELP! marx87 2nd Gen Engine & Drivetrain Tuning 2 Jun 7th, 2007 12:06 AM
BOV aka. Blow-Off Valve? burack 2nd Gen Engine & Drivetrain Tuning 3 May 8th, 2007 08:36 AM
Would this be OK with you Gennex body kit 911ETR Exterior 22 May 10th, 2004 10:08 PM
Are all replacement windshields the same? Dreamin Maintenance & MINI Care 1 Jan 7th, 2004 01:32 PM
