| MINI2 Newbie Join Date: May 2004 Local Time: 10:23 PM
Offline | Making the perfect start? What is the optimum RPM and and clutch release speed to get a fast start off the line with a Cooper S? Each time I try I either leave a trail of smoke as the wheels spin away or I don't give it enough grunt and it crawls away untill the revs build up? Any Ideas? |
| Blackpool Rock Join Date: Mar 2006 Location: Blackpool Local Time: 10:23 PM
Offline | Hi Adam, I hillclimb/sprint a Westfield in a roadgoing class. The intial launch is a critical part of the overall run because runs are so short. Also, a lot of venues split time at 64 feet so you can gauge your optimum start. My 0-64 feet times are better than most and this is what I have found to be best: I hold the engine at 3800rpm, then let the clutch out reasonably quickly (don't just drop it) and feed the throttle allowing slight wheelspin to prevent bogging but not spinning up. As soon as the tyres bite stamp on the thottle. There are two key points: Firstly: you have to find the optimum rpm for your car (probably higher than my Westfield) so as not to bog or spin up wildly Secondly: Your throttle should be fairly light (certainly not floored) until until the car is rolling. So long as you have fed and not side stepped the clutch, you won't have bogged (your launch rpm will prevent that) and your initial light throttle will prevent initial spinning up. It is a difficult balance, when you are practising just change one thing you do at a time otherwise you won't know where your improvement came from. Think I'll have a practice on the missus MCS today. Awsome car, luvit Kev. |
| The perfect standing start! | Andyb74 | MINI in Motorsport | 10 | Oct 13th, 2007 04:16 PM |
| start, stall, won't start | KTC | Faults & Fixes | 12 | Mar 27th, 2003 05:42 AM |
| Won't start.......................NOT cold start issue | Rwatts4mini | Faults & Fixes | 1 | Aug 8th, 2002 11:35 PM |
| Will not start period....NOT Cold Start Issue | Silly | Faults & Fixes | 31 | Aug 5th, 2002 02:35 PM |
