| MINI2 Regular Join Date: Mar 2006 Location: Melbourne, Australia Local Time: 07:55 PM
Offline | 6 speed manual reverse - OUCH! I've had my gorgeous new Cooper S for a week and a half, and am finding putting her in reverse rather painful - is there such a thing as Mini arm? Just wondering if this may ease up as she is run in, or if it needs to be adjusted to be less strenuous. I understand it shouldn't be TOO easy so as to avoid gear change mishaps, but as it is it seems quite OTT in the effort department. Am I alone in experiencing this? Many thanks, MsAmy. xox |
| MINI2 Regular Join Date: Apr 2005 Location: Brisbane, Australia Local Time: 06:55 PM
Offline | I believe it does get easier. We have had our MINI for six months and either (a) its getting easier or (b) I am just used to it more but at the start I had to use two arms to push it into reverse. A friend of ours told us that when he first got his MINI his wife had to run around to the passenger side, pull it into reverse and then run back to the drivers side. I hope you MINI is not as bad as that!!! |
Offline | Well, I haven't quite had to resort to the run around as yet - although the right arm has been utilised to push the thing across - so I guess I should be thankful. ![]() Maybe it's designed as a built-in muscle builder? ![]() (Thanks for your response - much appreciated.) MsAmy. xox |
![]() MINI2 Regular | The trick is to push the lever very quickly all the way to the left with force, if you gently push it to the left, hit the gate, and then try to push through the gate, it's quite difficult. Going at it full belt just gives you some momentum, and allows you to clear the gate with ease. Same as all BMW gearboxes. Hope this helps! |
| | #7 (permalink) |
| * Lab Rat * Join Date: Jul 2003 Location: Suffolk, UK Local Time: 09:55 AM
Offline | It does appear to get easier over time. I had a One Diesel, which is also six speed, and by the time I'd sold her it would slide across much easier - so much so I nearly had a mishap by selecting reverse instead of 1st ![]() |
| | #11 (permalink) |
| MINI2 Regular Join Date: Jan 2006 Location: Canberra, ACT Local Time: 06:55 PM
Offline | It must get easier over time ... I've had a couple of embarrassing moments at the lights (usually after I've been away for a while and not driven the MCS) when I've started to take off in the wrong direction Thankfully it has only happened when I've been driving sedately so I haven't floored it into the car behind me.Jas |
| | #12 (permalink) |
| Trained Monkey | This may sound like a cheap plug for a sponsor, but the whalen shift machine (www.whalenshiftmachine.com) weighs a tonne and really helps the feel of the shift, the weight added to the throw seems to make it less "clunky" and easier to shift (in my experience anyway). It does seem to get easier over time, but I don't know if it's more the operator, or the vehicle that changes, probably a bit of give on both sides. |
| | #13 (permalink) |
| Mazda3 Visitor | as many have suggested, start with the knob all the way to the right, and just slam it to the left, and it will go right through. Momentum is your friend here. My wife had problems at first, I showed her this, and now she has no problems whatsoever with it Minis rule, but so do Mazda3's, thank goodness I'm running in H-stock now though (only gotta deal with the regular Coopers now). . . |
| | #15 (permalink) |
| The MINITOR | It actually helps if you give it a bit of a slap. Actually take your hand off the knob and get that extra inch or so of slapping momentum and it goes right through. Before you know it you wont even think about it and the slapping is second nature. Another solution is installing a shift knob that sits higher. I had a knob on for a while that sat a few inches higher and the increased leverage made it way easier. Some like the added height too, closer to the steering wheel and stereo. Its all personal preference but the leverage was nice. |
| | #16 (permalink) |
| Blue is the colour! Join Date: Jul 2003 Location: Canberra, Australia Local Time: 06:55 PM
Offline | Amy it will get easier, as much as you will get used to doing so. However, I wish it had a lock up collar or something, a couple of times during vigorous downshifting on the track while doing a 3rd-2nd downshift I have shifted too aggressivley and initially placed the shift into the reverse gate, not fully into reverse fortunately. ![]() ![]() |
| | #18 (permalink) |
Offline | Cheers everybody! ![]() I think my left arm is becoming more muscular, as it is getting easier (the slap approach is helping too - so where do I tickle? )MsAmy. xox |
| | #20 (permalink) |
| Being normal is not fun! Join Date: Jul 2004 Location: Newcastle, Australia Local Time: 06:55 PM
Offline | As Paul said, one of the best things you can do is get a Whalen shift machine, they transform the driving experience as the knob is smaller (more suited to your hand), and heavier which means a much more positive shift - even though the knob is heavier it actually makes it easier to shift. |
| '05 Manual Tranny S - Speed Sensor? | Mudhen | MINI Cooper S | 0 | Jan 11th, 2007 07:59 PM |
| Reverse - Ouch! | minicooperobsessive | MINI Cooper | 50 | Jun 2nd, 2005 02:12 PM |
| Reverse and speed pulse connections | mellow | Interior & Ice | 0 | Sep 24th, 2004 06:17 PM |
| 6 Speed box / Reverse. | jamesgood72 | MINI Cooper S | 19 | Feb 6th, 2004 07:22 PM |
| Manual Air Blower Whistling at high speed? What Should I Do? | scott321172 | Faults & Fixes | 12 | Apr 8th, 2003 01:49 AM |
