Adam's Polishes
Old Aug 1st, 2002, 10:24 AM   #1
WAY
Local Time: 12:28 AM
Head lights
As I wasn't able to get Xenon on my car, I changed my light globes to something that was much brighter than the standard stuff. After much research, I went for the new Philips Crystal Vision, which is rated at 4000k (same as first generation Xenons). It's quite expensive (more than 50% more than blue vision) but well worth the money. I have a little problem. The left beam throw appears to be much closer to the car than the right. Anyone have any idea how to fix this???
Australia   Reply With Quote
Old Aug 2nd, 2002, 10:17 AM   #2 (permalink)
WAY
All fixed. My own fault. Didn't put the light bulb in on the right angle.
Old Aug 2nd, 2002, 11:25 AM   #3 (permalink)
disdis
disdis's Avatar
are the bulbs straight forward to install?
Hong Kong   Reply With Quote
Old Aug 2nd, 2002, 11:32 AM   #4 (permalink)
WAY
Yeah, pretty straight forward. The parkers are a pain though. Hard to reach to turn them. The low and high beams (I only changed the low beam) are on the bonnet, which makes it super easy to change. Oh, the parkers are also not worth changing. I thought I would match the low beams by using white globes, but with half the housing kinda orange, the parkers still looked yellowish. Waste of money there for sure.
head lights on when you switch off spikey 2nd Gen MINI Cooper 14 May 11th, 2007 12:07 AM
Yellow film for head lights MNIMGK Exterior 2 Oct 14th, 2006 04:23 PM
xenon head lights puccamini Exterior 5 Apr 5th, 2006 06:13 AM
Head lights Pippaki Exterior 2 Mar 10th, 2005 05:42 PM
Head lights? guitarhero MINI Cooper 8 Jul 2nd, 2002 11:42 AM
