Tags: , ,
Old Sep 26th, 2006, 08:48 PM   #1
fozworth
Local Time: 01:18 PM
Will i get a 30mm drop with eibach springs on a cooper s?
I would like coil overs but cant afford them so wounderd if eibach or H&R lowering springs would lower my cooper s 30mm from its current factory height as i under stand the cooper s is already lowerd .if this is so what spring will i need foe a 30mm drop on top of the current "lowerd" factory height. or do i have to use coilovers .
Old Sep 27th, 2006, 09:39 AM   #2 (permalink)
Tonyt3
Track addict
Tonyt3's Avatar
Local Time: 02:18 PM
Eibach sell different springs for the Cooper and the Cooper S. You dont have to use coilovers, but you might find the standard shocks not quite up to the job after running the springs for 12-18 months
Has anyone fitted FSD's with 30mm drop springs? Root Ginger Suspension 2 May 15th, 2007 04:31 PM
215x35x19 + 30mm drop MINIGREY Wheels, Tyres & Brakes 26 Apr 22nd, 2006 09:34 PM
1" / 30mm drop. mach01 Engine & Drivetrain Tuning 2 Jul 23rd, 2002 05:58 AM
