Visit Lohen!
Old Feb 10th, 2007, 11:13 AM   #1
sc00per
Local Time: 03:39 AM
DIY MCS tappet rattle - advice please
Hi
Hi i'm new to this forum but please can anyone help!!
I have a mysterious tappet rattle on my 2004 MCS. It only happens at startup from cold and only happens only 2-3 times a week. The rattle continues until and stop and restart the engine, then its usually instantly cured. The oil light doesn't come on and the oil level is where it should be. The car has covered just 29000 miles from new and I've never had a problem until now.
It has been back to the dealer for 2 days and the problem didn't occur so they didn't find it. Can anyone shed any light on this?
England   Reply With Quote
Old Feb 10th, 2007, 11:40 AM   #2 (permalink)
matt21
Now with S power!
matt21's Avatar
Local Time: 04:39 AM
Send a message via MSN to matt21
interested to here what is said here.
mine makes a similar sound, also done 29,000 miles and seems to do it at idle, particularly at cold. dealer could not identify it (as per usual) but still does it.
oil is also fine (altho old as its approching service) so a bit worried here too!
Old Feb 10th, 2007, 01:06 PM   #3 (permalink)
K1 LYC
210 of the finest horses
K1 LYC's Avatar
Mine does it too - dealership said it was oil level so topped it up and it was fine for a week or 2 then it came back - oil level is fine though.
United Kingdom Female View K1 LYC's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 10th, 2007, 01:43 PM   #4 (permalink)
R53 Cooper S
GP 1699
could it be the valve to the left of the intercooler?
Old Feb 10th, 2007, 03:06 PM   #5 (permalink)
matt21
Now with S power!
matt21's Avatar
it annoys me when the dealers dont know, not as uncommon as i first thought it seems
Old Feb 10th, 2007, 03:22 PM   #6 (permalink)
Wurzel
Oh arr
2005 MCS 13000 miles
I visited dealer with what I thought was tappet noise, turned out to be valve to left of intercooler as suggested above, (something to do with fuel and emmisions).
If you put a big screwdriver on the valve or piece of tube the tapping resonates through it.
Also close your hand around valve and tapping noise gets quieter.
Other than that I saw a post on here a while back about faulty valve lifters which caused noise you describe.
Good luck.
United Kingdom View Wurzel's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 10th, 2007, 05:10 PM   #7 (permalink)
sc00per
hi guys thanks for the replies
i've checked the valve to the left of the intercooler and its ok, the problem i've got is definitely with the valve lifters and its worse with a cold start....looks like another trip to the dealership
Old Feb 10th, 2007, 08:56 PM   #8 (permalink)
PmP
GP 0380
PmP's Avatar
46,000 miles and on thursday there, I started the car and there was a loud tappet noise.
I at first thought it was the fan or supercharger belt, but when I went to rear of the car you could here the engine/exhaust note almost pulsing at the same rate as the noise in the engine.
Sort of a tappety noise the repeated about twice every second. First time its happened tho.
It continued for a couple of minutes, until I moved the car about the yard a bit. A bit worried somethings wrong.
On another note on start up of my car I have experience the speedometer needle vibrating wildly for about 5 seconds.
Northern Ireland Male View PmP's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 10th, 2007, 09:01 PM   #9 (permalink)
K1 LYC
K1 LYC's Avatar
I think that the speedo, oil temp and fuel needles vibrating is normal. I'm sure there is a thread here somewhere about it. Mine does it too. Something to do with it calibrating itself I believe.
Maybe someone can confirm??
Old Feb 11th, 2007, 12:41 PM   #10 (permalink)
Alex5
I used to have an MX5 with the similar tappet/hydraulic lash adjuster setup, it was not uncommon for this subject to come up frequently for higher mileage cars on the forums I used to be on.
In the case of that car it was generally either down to the small bore channels which allow the oil in and out of the tappets becoming blocked with dirty/old oil (so they would not adjust anymore and become loose insted of taking up the clearance properly), or the actual spring within the tappet collapsing (much less common).
With the long oil service intervals, especially under TLC, I would have thought blocking could be a possibility. Flushing the engine with Wynns or equivalent engine flush when changing oil should clear this out, worth a try?
Alex
Old Feb 11th, 2007, 11:26 PM   #11 (permalink)
PmP
GP 0380
PmP's Avatar
We'll I went to take car out tonight and to my horror, the tappety noise was there again. So I checked the oil level, which was low!!
So I topped it up with remaining oil from the litre bottle in boot. Going to get some more at dealers tomorrow.
Then I looked into my Mini TLC servicing shedule and warranty. Which I thought was bullet proof and would treat my mini correctly.
I assumed that the car had had its oil changed twice, as it had had its first oil change and first inspection.
To my horror, It only been changed at 11,000 miles. And according to my trip it doesnt need changed until at least 50,000 miles!!! And spark plugs should only be changed at ever third oil change!!!!
So needless to say at 45,000 miles I am going to get my MCS serviced oil change, filters, spark plugs the lot right away and get them to investigate the tappety noise. And the creaking steering column. And im never relying on TLC again.
Old Feb 12th, 2007, 09:32 PM   #12 (permalink)
Marlan McLeish
Wow, make that another of the exact same problem here, I get the tappet noise at startup on cold idle until a few min into journey then it just disappears (when engine is warm.) mines at 26k with 7k to next service. Also suffering from knocking/click noise from lock to lock in steering (also occurs if go over bump or pavement while on lock.)
Not a convincing start to my keep it or trade it decision coming up to my 1yr of ownership, especially when warranty runs out in June.
Old Feb 13th, 2007, 09:41 AM   #13 (permalink)
PmP
GP 0380
PmP's Avatar
Aye, mines booked in to be checked out, aint heard the tappety noise since I put some oil in tho. Car seems to have used a little water from the water reservoir as well.
Warranty runs out this sunday, so just as well I went and got it booked in. Was told additional warranty is £600 for 12 months.
So pending them sorting this problem I have to decide whether to keep or trade in. Dont particularly want to change nothing else out there somes interesting at moment.
Old Feb 14th, 2007, 02:28 PM   #14 (permalink)
zero_cool
zero_cool's Avatar
United Kingdom Male View zero_cool's Solid Black & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Feb 18th, 2007, 02:59 PM   #15 (permalink)
Alex5
Have any of you with the tappet rattle had an engine flush and oil change yet?
Be interested to hear how you have got on
Old Feb 28th, 2007, 12:57 AM   #16 (permalink)
Babes
Cruising In The Minge
Babes's Avatar
Local Time: 11:39 AM
I get a slight rattle on start up but only or about 30 seconds then its fine. Did have the horrid squeeky steering column, got that fixed (replaced) while still under warranty.
2003 BRG/W JCW MCS
2002 PS/PS JCW MC
1970 BRG/W MK2 Morris Cooper S
Australia Male View Babes's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 28th, 2007, 07:16 AM   #17 (permalink)
Ant FR
i get that on start up, but I am 1000 miles away froma n oil change so that must make a difference, seeing as it was last changed in 2005. Damn you long life service schedule. deliberatetly racking on the miles to get it done before Nurburgring trip....lol
Old Mar 22nd, 2007, 12:26 PM   #18 (permalink)
PmP
GP 0380
PmP's Avatar
Ok I topped my oil up til its high on dip stick and noise didnt happen for about two weeks, happened two days ago on a really cold morning, but only for 5 seconds.
However, our GP which only has 1100 miles got started yesterdar and on start up made the same tappet noise, but only for like 5 seconds.
So I'm guessing its just the pulley belt getting wound up to idle speed.
Old Mar 22nd, 2007, 12:56 PM   #19 (permalink)
zero_cool
zero_cool's Avatar
I eventually got mine cured. The dealer had it for a full week and eventually heard the noise. They replaced the valve lifters and it's ok now.
Hope that helps
Old Mar 22nd, 2007, 10:25 PM   #20 (permalink)
PmP
GP 0380
PmP's Avatar
Hope that helps
I dont think valve lifters are needed on a Gp with 1100 miles . How many miles had you up on your mini? my S is at 46,000. Could be on my S as the tappet noise can go on for minutes.
mcs engine rattle crspaffo Faults & Fixes 4 Apr 27th, 2007 05:21 AM
New MCS, but rattle from back.... Andyman MINI Cooper S 24 Dec 28th, 2004 01:04 AM
Sounds like Tappet rattle ? northandy Faults & Fixes 0 Jun 26th, 2003 08:43 PM
rattle in a red MCS timmy MINI Cooper S 1 Nov 12th, 2002 04:55 AM
'Tappet Bros' recommend MINI Cooper karmuze MINI in the Media 8 Jun 13th, 2002 10:25 PM
