Mini Pirate
Old Jun 4th, 2007, 08:06 PM   #1
GARY GP
GP-1528
GARY GP's Avatar
Local Time: 12:06 PM
gtt
Eyes up Anyone else had probes with gtt aerobox strut brace. there is one for sale in the classifieds he has had stainless inserts fitted after his came loose
Old Jun 4th, 2007, 08:12 PM   #2 (permalink)
russyellocoops
having fun or hungover...
russyellocoops's Avatar
Send a message via MSN to russyellocoops
Shouldn't move if torqued up properly!
also possibly a bit of thredlock to stops them working loose!
a hole will only go oval with friction and only possibilities of friction is if it's come loose!
I'm in no way related to Roland, but i'd thought a chat would be better than a rant on here!
United Kingdom Male View russyellocoops's Liquid Yellow & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Jun 4th, 2007, 08:45 PM   #3 (permalink)
Tigger, Eeyore & Roo
I'm Back!
Tigger, Eeyore & Roo's Avatar
What's going on here?
This is a high quality item and I am sure Roland will help you if you are having a problem. I'm still not certain what the problem anyway Please explain.
Tigger.
Unintimated and I'm back!!
For sunshine, fun and Cornish Pasties: New MINI Kernow Cornish Oggy Run 2009!
United Kingdom View Tigger, Eeyore & Roo's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 4th, 2007, 08:58 PM   #4 (permalink)
ScottyBoy
Obsessive Car Cleaner OCC
ScottyBoy's Avatar
Im in no way having ago either but theres a member selling one in the classifieds section "various parts" and he says his is away having SS inserts fitted in parts this might be the same thing possibly.....
Old Jun 4th, 2007, 09:05 PM   #5 (permalink)
I'm Back!
I had mine fitted by Roland. I think that he replaced the originals nuts when he fitted it and it's never budged a millimeter. I've even taken it off (to change the oil filter) and replaced it myself and had no problems at all, and I'm a fussy old bu99er!
Please speak to Roland about this before posting -ve comments
Thanks,
Tigger.
Old Jun 4th, 2007, 09:09 PM   #6 (permalink)
Hartge210
Zippy - GB210
Hartge210's Avatar
No problems with mine, & it gets USED
I'm sure Roland will put a few things straight
Falkland Islands Male   Reply With Quote
Old Jun 5th, 2007, 01:12 AM   #7 (permalink)
PmP
GP 06 MCS 0380
PmP's Avatar
300GP you're posts are very broken english, please explain further. Was this car lowered? Perhaps jappers himself can explain.
Northern Ireland Male View PmP's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 5th, 2007, 02:19 AM   #8 (permalink)
GARY GP
GP-1528
GARY GP's Avatar
i personally don't know japper he is selling his brace in the classifieds! he said his brace came loose mis shaping the holes. he is now having his fitted with stainless steel inserts don't shoot the messenger
Old Jun 5th, 2007, 07:03 AM   #9 (permalink)
rkw
Local Time: 04:06 AM
I do not see a benefit to fitting an insert, unless the hole had become so enlarged that there is a poor mechanical interface between the nut/washer and the brace. The insert would only serve to cosmetically make the hole look round. The fundamental problem is that one or more nuts had worked themselves loose and this eventually allowed the bolt to rub against the hole. Nuts can come loose on any strut brace, and it is an issue to watch for whether the brace is GTT or any other brand.
United States View rkw's Pepper White & Black 1st Gen MINI Cooper Convertible Profile   Reply With Quote
Old Jun 5th, 2007, 10:35 AM   #10 (permalink)
Aberdeen Al
Aberdeen Al's Avatar
If you use the Nyloc nuts (nut with a nylon insert which basically locks the nut in place) provided by GTT when you purchase the GTT strut the nuts and torque them to the correct setting then you won't have this problem - trust me.
Vroooom Vroooom
Old Jun 5th, 2007, 10:57 AM   #11 (permalink)
Japper
Japper's Avatar
It is me that is selling the modified brace. In fairness this was because I found that the std. nuts kept coming loose, so in a rush I used the nyloc nuts with no washer ( don't think there's room for a washer anyway. When I took the brace off to fit new air filter I noticed that I had 'squashed' and elongated the holes. This probable doesn't effect the performance of the brace once it's 'bedded in' to this position, but being a bit picky decided to engineer in some harder inserts.
Then i heard about the new 08MCS specs. and decided to take a test drive........big mistake
So it's up for sale......................a one off
Some other parts still up for grabs guys / gals.
06 HB/W MCS Chilli
Scotland View Japper's Pepper White & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Gtt 1andy MINI One 2 Apr 3rd, 2007 02:29 PM
CAI/Induction. Alta vs GTT vs JCW/GTT vs K&N etc... Which to choose? AMF310182 Engine & Drivetrain Tuning 25 Feb 24th, 2007 12:53 PM
Gtt holkin Engine & Drivetrain Tuning 2 Nov 25th, 2006 04:43 PM
Another GTT S is born! uncle albert Engine & Drivetrain Tuning 33 Oct 17th, 2006 02:49 AM
GTT JCW Hybrid vs GTT CAI cooper7 Engine & Drivetrain Tuning 1 Aug 4th, 2006 09:07 AM
