Visit Lohen!
Tags: , , , , ,
Old Aug 13th, 2007, 10:13 PM   #1
mmilgrom
Local Time: 05:02 PM
Australia Whining / Low-pitched squeak pulling away from rest
Greetings fellow MINI enthusiasts.
After lurking in the forums and checking online car sale websites for around 5 months, my wife and I finally succumbed to the cult of MINI a couple of months ago and purchased a 2nd hand 2004 Cooper S Chili with all the trimmings. It had covered a paltry 38,000 kms and had been pampered and polished. Thusfar, we've loved every moment of ownership even with the odd little rattle and the underwhelming fuel economy.
Recently, however, our beloved MINI has developed an odd whining sound. I'm not talking about the missus complaining as we have to fill up with 98 octane petrol yet again, and I'm not referring to the comically loud power-steering whining which would embarrass Jonny 5 of Short Circuit fame.
This sound only appears when pulling away from rest in 1st gear. It occurs for less than a second, is relatively low-pitched and sounds like a lower-pitched version of the sound you get when rubbing the rim of a wine glass with a wet finger. The sound only appears very occasionally, and there doesn't seem to be correlation with any other events (hot / cold car, warm / cold day, wet / dry conditions). All I know is that the sound appears to be presenting itself more frequently (say, once every few days). Needless to say, this is NOT the low-pitched grumble which occurs upon pulling away for the first time on a journey: I know that the ABS system has a little 'practice' and I'm not confusing the two.
My very limited powers of deduction have isolated it to one of the following areas:
- Brakes (perhaps binding at standstill and then freeing?)
- Clutch (We do live in Sydney: the previous owner could have been a lazy left-footer)
- LSD (Wish I knew more about how they worked and whether they make such noises)
It had its 40,000 km inspection service a few weeks ago and was given a clean bill of health then.
Any ideas?
Matt Milgrom
Australia   Reply With Quote
Old Aug 14th, 2007, 09:15 AM   #2 (permalink)
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
Local Time: 08:02 AM
Sounds like a slipping belt.
It was acceptable in the 80's
Old Aug 15th, 2007, 01:49 PM   #3 (permalink)
minigolf
Blue is the colour!
minigolf's Avatar
Yeah, could be slipping belt. And, unless it is a January 05 build, or later, it won't have the limited slip diff either.
Hope it gets sorted for you soon.
Cheers Liam
Australia Male View minigolf's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 19th, 2007, 11:22 AM   #4 (permalink)
C00P3R S
Any ideas?
Matt Milgrom
Hi Matt,
Did you ever solve the problem? seems like I may have the same issue!
Would love to know if you ever got to the bottom of it!
Thanks Steve.
Old Nov 19th, 2007, 09:19 PM   #5 (permalink)
rellik666
Keeping The Top Off!
rellik666's Avatar
Send a message via MSN to rellik666 Send a message via Skype™ to rellik666
Hey!
Only just saw this. My late 02 MCS also has this noise and it has been to garage several times. There is also no correlation to when it happens, but it has got less frequent. It has done it all the time that I have had it, 18months now, and never caused a problem. Happens once maybe twice then doesn't do it again. No luck with a diagnosis, but not worried about it.
As mine is pretty early I have a few quirks that I live with, and this to me is just another one. Doesn't effect performance or drivability so I am happy.
What difference would a limited slip diff make?
Don't early ones have this? Would my 07 cabrio have it?
OH MY OH MY! I own a Sidewalk!Almost.........
Australia Visit my Blog at the Motorcade Female View rellik666's Pepper White & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old Nov 19th, 2007, 09:26 PM   #6 (permalink)
Mike Clarke
You are number 6
Local Time: 03:02 PM
Send a message via Skype™ to Mike Clarke
This sounds like a clutch bearing.
I have the same problem and there are a few posts in the faults & fixes forum on this.
Australia Male View Mike Clarke's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 19th, 2007, 10:28 PM   #7 (permalink)
ScottyBoy
Obsessive Car Cleaner OCC
ScottyBoy's Avatar
The explanation of this sound, sounds like the problem i recently had, as my car was under warrenty i went to the dealer and from reading another thread about this i was aware that it could be something related to the flywheel. The dealer replaced the flywheel and clutch under warrenty without hesitation. Although dont take my word on it that it is and you have a major fault as yours could be very minor.
Scott
Old Nov 21st, 2007, 06:55 AM   #8 (permalink)
Scourgebk
Agreed, the high pitched whining sound pulling from 1st gear sounds like the clutch bearing. Upon purchase of my reconditioned MINI, I complained about this and the dealer mentioned that the whining sound came from the clutch bearing.
When the clutch components (bearing, pad and plate) are removed, can I just change the bearing only or do I need to change all 3 items?
I was told that removing the gearbox is really cumbersome and since it has been removed, it is better to change all the components.... .
Malaysia Male   Reply With Quote
Old Nov 23rd, 2007, 09:54 PM   #9 (permalink)
micky.b
Local Time: 07:02 AM
Talking
My MCS does exactly the same thing and it's really anoying. I can reproduce the noise when pulling away in 1st gear and reverse. It used to only happen when the car was cold but is getting more frequent and can happen at any time.
Car has been back to the dealer for Gbox, clutch and flywheel but it is still singing to me.
I can also get/force the noise when stationary with the handbrake on (it's not brake binding noise) and riding the clutch in the lower gears 1,2 and 3 car just bogs any higherup the tree.
mmilgrom's Wine glass analogy has struck a chord with me and I'm wondering if the dual mass flywheel is vibrating on take up?
I can get the noise to go away if I heat the clutch up ( handbrake on, 1st gear and slip clutch for 20 seconds) All is quiet untill it all cools down.
Although I dont like the noise it kind of sounds like it's bored and yawning at me - just makes me drive it harder to quieten it down. mmm.
England   Reply With Quote
Old Nov 25th, 2007, 12:43 AM   #10 (permalink)
Lav3r
Ari Gold
Lav3r's Avatar
I had the same problem a few weeks ago.
Check out my thread here: http://www.mini2.com/forum/mini-coop...ch-squeak.html
Basically, I bought a used Mini from a Mini Dealer and only when I recieved it I noticed a loud squeak/whining noise everytime I pulled away in 1st, especially when it was cold.
Complained to Mini, they got the car in to diagnose the fault, and they replaced the whole clutch free of charge.
Old Nov 25th, 2007, 10:33 AM   #11 (permalink)
simeds
IM ALSO A COUNTRY MEMBER
simeds's Avatar
Send a message via MSN to simeds
sounds like clutch flywheel to me, based on my experiences
I I'VE FOUND NEMO
Old Dec 1st, 2007, 09:35 AM   #12 (permalink)
Shaun
Mr Big Stuff
Shaun's Avatar
I asked one of the JCC mechanics about this mine has done it since new and still does. He said bent flywheel and that it was a known problem. I just put up with it I could not be bothered trying to get a fix when it involved so many parts being ripped out. The car is no worse after 2 years and 18000 miles and its going in two weeks so look out for the...
I have just bought a used Cooper s from Rochdale and it squeaks in first gear Thread soon
United Kingdom Male View Shaun's Pepper White & Black 2nd Gen MINI Cooper Clubman Profile   Reply With Quote
Squeak when pulling away matc Faults & Fixes 37 Feb 14th, 2008 04:27 AM
Low pitched drone from engine / exhaust moonshine Faults & Fixes 15 Apr 27th, 2006 02:11 PM
Squeak when pulling away Olly. Faults & Fixes 7 Aug 3rd, 2005 08:11 PM
high-pitched oscillating sound at low RPMs petsounds Faults & Fixes 2 Jun 13th, 2004 07:39 AM
Squeak...squeak...squeak from the engine bay? v8voodoo MINI Cooper S 15 Dec 31st, 2003 05:19 PM
