| Tags: filter |
| MINI2 Regular | Air Filters, service! How often do you guys change them? It seems MINI doesn’t change them as part of the TLC oil change, as I can’t find no mention of it in the service manual? Why? I am thinking of changing it myself, why is this not changed with the oil and oil filter? Do you need to ask for it as extra and pay for it? Knowing MINi they will probably want an hour’s labour! So that would be £8 for the part, and £100 for the labour. |
| Mini Convert.... Join Date: Oct 2006 Location: Biggleswade, Beds.UK Local Time: 02:17 PM
Offline | I have a washable K&N, i tent to clean that about every 10,000 miles, so on each service. If its been a very dusty few months (i live on a farm) i wash it every 5,000 miles. |
| | #7 (permalink) |
| THE STICK Join Date: Feb 2003 Location: Worcestershire WR15 Local Time: 02:17 PM
Offline | Never ever leave it to BMW to change it as part of the service. The time between changes is far too long. On an S certianly need to change it more frequently than the TLC/service intervals. It take 2 minutes and a torx bit/screwdriver and 0 mechanical knowledge to do. Cost if you do it every 10k is about £3 for a filter. If BMW do it every 10k they will charge a lot more! My advice is to buy a panel filter like piper or kN (they do not alter your insurance) and then wash and oil them every 10k at least yourself. |
| | #9 (permalink) |
Offline | If I remember right (I have had an Alta CAi for ages) then its either just some small clips or a couple of torx bit scres that keep the lid on the stock box. Take the lid off and take the panel out...throw away and fit a replacement paper panel or an uprated KN/pipercross one. Screw the lid back on. Worth investing in a haynes manual for £14 from halford...its been invaluable to me |
| | #10 (permalink) |
| MINI2 Newbie Join Date: May 2007 Local Time: 01:17 PM
Offline | Ive just cleaned the air filter and put eeverything back together okay i cant get the metal clip to back together. Any tips? should i buy i new one and were from? Thanks in advamnce for any help |
| | #11 (permalink) |
| MINI2 Newbie Join Date: Jan 2007 Location: Nere Sittingbourne Local Time: 02:17 PM
Offline | When i got my 03 MCS last November the car had 32000 mile on the clock and if you drove it hard you could here a loud chattering noise from the engine, i had the car inspected by my local mini dealer but the could not find any fault with the car and i was told not to worry about it ![]() Anyway to cut a long story short i decided to fit an Alta cold air kit, so on removel of the old air box and filter i found the filter Tobe very dirty and misshaped. ![]() Now the car runs alot smother and the noise has gone. although the TLC pack looks good value i do think they are skipping on what would be normal replacement service items ![]() |
| | #12 (permalink) |
Offline | The clip is a sort of almost one use. I am assuming you mean the sort of jubilee ring clip on the air pipe? The way most people deal with it is they get the old one use (it can be reused but difficult) and measure its diameter...then go to halfords/supply place and buy a corect size jubilee ring and use that instead...makes for easier removal and refit at later dates. BMW also can sell the proper clip to you for a few pennies. R |
| | #13 (permalink) |
Offline | Oh if you want to you can get a pair of needle nose pliers and use them to pinch the 2 humps together until the little pin slots into the hol and closes the ring clip up. Brute force and careful manipulation will work if the original clip is not too damaged. |
| | #15 (permalink) |
| Blackpool Rock Join Date: Mar 2006 Location: Blackpool Local Time: 02:17 PM
Offline | Mine was like that too - I can't work out why they pull in at the left hand edge as in your pic - not good as that will leave part of the route through the air box unfiltered. |
| | #17 (permalink) |
| 05 MCS BEP | Use adjustible pliers to squeeze the two sides of the clip together. Those are the type plumbers use. You can adjust the angle in which the claws grab the clip. When you squeeze the clip together, it should just snap in. If you must use regular pliers, the angle on which the claws contact the clip causes the pliers to slip off and it doesn't work. 05MCS BEP - Alta 22mm rear anti-swaybar, Madness CAI |
| | #19 (permalink) |
| MINI2 Sponsor Join Date: May 2006 Location: Sunny Blackpool Local Time: 02:17 PM
Offline | Hi The air filter is changed on the inspection 2 service which would be arould the 50.000 mile mark, if you want to replace the filter early the fitted price is £14.95 inc parts labour and vat Chris ![]() |
| | #20 (permalink) |
Offline | Why are people removing the air pipe clip? - If you remove the Intercooler plastic cover, there is enough room such that the air box lid/pipe can be lifted forward with the pipe still on. Kev. |
| Air Filters | FunkyJMan | Engine & Drivetrain Tuning | 1 | Nov 13th, 2005 07:37 AM |
| Air Filters plus a little more... | FunkyJMan | Engine & Drivetrain Tuning | 3 | Sep 18th, 2005 05:25 PM |
| air filters | kenny78 | MINI Cooper S | 1 | Jun 15th, 2003 10:31 AM |
| KN air filters | kkpalmer | Engine & Drivetrain Tuning | 4 | Oct 17th, 2002 03:00 PM |
| Compare air filters | Yui | Engine & Drivetrain Tuning | 0 | Jul 11th, 2002 01:34 PM |
