| MINI2 Regular Join Date: Jul 2002 Location: Indy Local Time: 03:11 AM
Offline | Has anyone else had this vibration problem? I've noticed a vibration noise since new (now 5 days old)and traced it to the tachometer. When I grab the tach the vibration/buzz stops. I was thinking of putting Dynamat on the back of the tach to stop the buzz. Any thoughts? Jim ![]() |
| MINI2 Master Join Date: Apr 2002 Local Time: 09:11 AM
Offline | tacho saddle Pretty much agree with Dom. The tacho saddle is the piece of plastic below the tacho that straddles the top cowling of the steering column. It sounds like this could be the culprit. I doubt the screws are loose, but as Dom pointed out, maybe one is. If not, the saddle may need removing, perhaps reshaping, and replacing in order to eliminate buzzes from the contact between it and the top cowling and/or tacho. To do this, you want to increase (not decrease as you may think) the contact between saddle and cowling. If you're up to the job yourself, try this, although make sure first that the tacho saddle is responsible for the noise to save time and disappointment:- It's two tx 20 type screws behind the tacho. Remove them and the saddle will seperate from the tacho. Gently bend (preferably after heating with a heatgun or decent hairdryer) the saddle so that it offers a better fit when replaced. Aim for it to be as flush as possible to the cowling. This usually just means bending both sides downward a bit. This can be achieved to a degree without a heatgun, but be gentle and stress the plastic gradually or it will just snap. When refitting, the screws may constantly feel like they are about to cross thread. It's a characteristic, and they never do. If your not diy inclined, contact your dealer. Last edited by MiNiGuY : Oct 15th, 2002 at 12:49 PM. |
| Steering wheel vibrates... | MINI-LOVER | Faults & Fixes | 2 | Apr 3rd, 2006 12:36 AM |
| Engine revs to about 2000 rpm when starting | Scoobystu | Faults & Fixes | 5 | Jul 21st, 2005 09:20 PM |
| RPM/Tach Signal? | Andy@Ross-Tech.com | Engine & Drivetrain Tuning | 21 | Mar 23rd, 2004 01:27 PM |
| At What RPM Do Your "Buzzes" Appear? | kshapiro | General Discussion | 10 | Apr 23rd, 2003 02:54 AM |
| Queen Mum R.I.P. 1900 - 2001 | Dogger | General Discussion | 5 | Mar 31st, 2002 04:21 AM |
