Old Jan 23rd, 2005, 12:52 PM   #1
Bandito
Local Time: 01:06 PM
England Steamy Windows
My 53 JCW Cooper S front windows have a steam problem. There is a distinctive line where half of the window from sill to roofline condensates obstructing my view of the wing mirrors, however the rest of the window is fine, does anyone else get this problem?
Old Jan 23rd, 2005, 01:21 PM   #2 (permalink)
nylo
Shar! I'm coming darling!
nylo's Avatar
Local Time: 02:06 PM
yeah, i have that too. not sure whether its actual condensation, as it only seems to appear after ive lowered the window and raised it again. it's almost like there's something rubbing against it when it it's down. Haven't really got to the bottom of it, depsite it being very annoying, especially when your car is lovely and clean, inside and out, and then you get this big streaky line, so can't really give you any tips or advice as to what it might it be, or how to get rid of it...
Northern Ireland Female View nylo's Space Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 23rd, 2005, 03:29 PM   #3 (permalink)
paco
I'm not an addict.
Local Time: 09:06 AM
Send a message via AIM to paco Send a message via MSN to paco
Hi guys,
This problem is most likely caused by dirty rubbers around your windows. I had a similar problem, and during one of my car washes last summer I decided to wash the rubbers with some rubbing alcohol. The problem went away after for the most part after that.
paco
Canada Male View paco's Cosmos Black & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jan 23rd, 2005, 04:25 PM   #4 (permalink)
nylo
nylo's Avatar
Quote: Originally Posted by paco
Hi guys,
paco
when you say washing the rubbers, is that just the bit you can see and get at, or did you have to dig deeper than that, so to speak?
Old Jan 23rd, 2005, 05:16 PM   #5 (permalink)
Hat
Wolves Did It!
Hat's Avatar
Online
this sounds like a repeat of an old problem. basically there's some pre-delivery residue on the weather strips inside the door panel which transfers onto the window. your dealer should know all about it & needs to strip off the weather seals & either clean them or refit new ones.
Old Jan 23rd, 2005, 06:55 PM   #6 (permalink)
nylo
nylo's Avatar
Old Jan 23rd, 2005, 06:58 PM   #7 (permalink)
paco
I'm not an addict.
My dealer simply told me to clean them off myself
paco
Old Jan 23rd, 2005, 08:06 PM   #8 (permalink)
nylo
nylo's Avatar
Old Jan 23rd, 2005, 09:52 PM   #9 (permalink)
Bandito
This only affects part of both front windows and there is a clear line which makes them look like there is a quarterlite window there like on the first of the line Mk2 Golfs, are we still talking about the same problem?
Old Jan 24th, 2005, 07:37 AM   #10 (permalink)
Hat
Wolves Did It!
Hat's Avatar
Online
yep thats exactly how it looks. this has been a problem almost since the very first cars, i can't believe its still happening. besides the annoyance factor its dangerous not to be able to see your wing mirror because of this streaking
Old Jan 24th, 2005, 04:42 PM   #11 (permalink)
nylo
nylo's Avatar
hadn't thought of the danger factor, it's just bloody annoying!
Old Jan 24th, 2005, 10:07 PM   #12 (permalink)
Bandito
So basically I could ask BMW (Mini) to change the windows but chances are this is not gonna fix the problem, that is if they agree in the first place!!
Thanks all, at least I know I'm not the only one........if anyone else has a way of rectifying the problem I'm all ears
Old Jan 24th, 2005, 11:50 PM   #13 (permalink)
Cooper76
MotorCityMadman
Cooper76's Avatar
Drive with the windows down at all times.
***BMW-AG Rocks!!!***
Portsmouth FC Can Thank Sunderland...What a Farce!!!
United States Male View Cooper76's Solid Black & Body Color 1st Gen MINI Cooper Profile   Reply With Quote
Old Jan 25th, 2005, 04:30 AM   #14 (permalink)
kezman50
Yep ...I get it too. My cars an 05 model with only just over 2000 miles on it.
Old Jan 25th, 2005, 06:57 AM   #15 (permalink)
Hat
Wolves Did It!
Hat's Avatar
Online
not the windows, just the rubber weather strips
Old Jan 25th, 2005, 07:53 AM   #16 (permalink)
scooperman_uk
almost 59k
scooperman_uk's Avatar
re streaky windows.
after moaning about it on a regular basis i got the seals replaced under warranty. no more lines on the window.
steamy windows, might be you air flow, are u running with the settings on do not replace air with external as this can cause a build up of heat. this happens quite often on my 53 CoopS, i just run the aircon for a while with the heat on and it usually resolves the issue as it works as a de-humidifier.
United Kingdom View scooperman_uk's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 25th, 2005, 02:24 PM   #17 (permalink)
Cooper76
MotorCityMadman
Cooper76's Avatar
OK, so then this is something they will generally admit to and replace for you?
Old Jan 25th, 2005, 05:05 PM   #18 (permalink)
nylo
nylo's Avatar
bit of a pain though, even if they will replace under warranty!
steamy windows cmwilmott MINI Cooper S 9 Nov 3rd, 2006 12:42 PM
Windows.... -=cHiLli=- General Discussion 6 Jul 14th, 2005 12:30 PM
Windows mtuk Faults & Fixes 2 Oct 9th, 2004 10:54 PM
Steamy Windows? Jazzy Jase Faults & Fixes 10 Dec 26th, 2002 10:06 AM
