| MINI2 Newbie Join Date: Mar 2005 Local Time: 09:14 AM
Offline | LSD vs regular manual I put a deposit down on a 2005 MCS. It has manual with LSD. I have to travel from San Francisco to Los Angeles to pick it up and drive it back. A local deal just informed me that I can get a MCS (someone ordered one but changed his mind) locally. This one only has a regular manual (no LSD). they both have very similar options: premium, sport, leather, plus a few extras. The cost is $300 apart. This will be my second car. I like taking twisty drives in the mountains. I chose the Mini for its fun factor (over lexus, infiniti, and honda). At this time, based on what I read on this board, LSD is the way to go. However, if I get the Los Angeles car, 1. the break-in miles will be 400 miles of continuous driving. may not be the best thing for the car. 2. service will not be at the dealer I purchase the car at so they may not be as happy with me. 3. would it make that much of a difference? |
| MINI Fan (atic) Join Date: Dec 2004 Location: London Local Time: 10:14 AM
Offline | Get the one with LSD.... IMHO, anyway...... The information you have based on what you read is the correct one... 1) Break-in of 400 miles continuous is no problem as long as you vary speed and gears every now and then (just slow down, change to 5th or 4th, and speed up every 10-20 mins) Will do no harm at all, and you will be 400 miles less to go till you can give it some stick...! The MCS really gets going after 4500rpm and you cannot use this till broken in. 2) They shouldnt be too bothered as you are coming in for service, and all the other bits and pieces you will need once you get the car. Trust me, it is like an addiction.3) No!!! Depends if you are tight, but if the far one is cheaper, at least you will have gas money for free, and a little for 2) above.For what it is worth, I believe it is better to have LSD and not need it, than to need it and not have it. Imagine if you got the one without and then drove one with and loved it..... It also helps resale (a little) as LSD is worth £100 extra in UK (not sure what the difference is in the US) |
| | #6 (permalink) |
| MINI2 Regular | If you take it on a track (road or drag), yes you will definitely want it. If you are just using it on the street - you will never know it's there or not. It's not some magical device like some people make it out to be. It's only a benefit under some circumstances. I have no interest in or easy access to tracks, so it makes zero difference to me. I saved the money. No regrets! |
| | #8 (permalink) |
| MINI2 Newbie | I think you will be happy going with the LSD. My 2003 S (no LSD) would burn through the inside tire if you accelerate aggresively out of a corner. Yes it is fun to leave the people behind you in tire smoke, but it isn't the most effective way of driving. The LSD should solve this issue, and if I order another, it will definitely be LSD equipped. ![]() |
| | #12 (permalink) |
| AWOL | I beg to differ, the LSD makes a big improvemnet, and you dont need to be thrashing round a track to feel its benefit.... out driving down a country lane and come accross an area of road that has different surfaces on each driven wheel, say gravel one side and asphalt the other the LSD reduces the effect on the wheel on the slippy surface, meaning the wheel on good ground doesnt lose power and drive.... On twistys, you are pressing on and not neccasarily speeding or driving dangerously into a corner, accelerate, instead of the inside wheel scrabbing for grip, the outside wheel keeps the same speed and pulls you throough the corner... IMO all powerful front drive cars should have an LSD..... it also helps reduce torque steer on quick getaways.... |
| | #13 (permalink) |
| MINI2 Newbie | I will agree that driving recklessly on the street is a no no, however, with the DCS off you hardly need to drive aggressively to do that. I should have mentioned that I meant taking a corner from a stop. For example, stopped at a stop sign and taking a left. With the weak pickup down low in my old 03 it didn't even appear that I was driving aggresively. It was just that once the supercharger kicked in, all the weight was on the outside wheel. So the inside wheel just spins. Lifting and spinning the inside tire while already moving can be a bit dicey. I think that only happened once or twice, in fact I cannot remember it happening at all but I'm guessing it did. I became a fanactic DCS switcher offer for the first few months I had the car. After I learned how to drive the car, I always left it on, with it hardly activating ever. My next MINI will DEFINITELY see a track, and be LSD equipped. Good luck with the new MINI!!! ![]() |
| | #15 (permalink) |
| MINI2 Senior Join Date: Nov 2004 Location: Derby Local Time: 10:14 AM
Offline | Well, this being my first MINI, I have nothing to compare it to cept my previous car which was a tuned 200hp Golf Mk4 1.8T.. On a tight corner at speed the Golf was left scrabbling for power and the inside wheel would spin, the MINI just pulls you round the bend, you can feel it kick in. In saying that, you can feel it at normal relaxed driving speeds round a corner, pulling away or just on loose surfaces. Its always on and gives the car incredible traction! You're gonna love it, the DSC hardly ever feels the need to kick in! ![]() |
| Regular Maintenance... | lionhearts | MINI Cooper | 23 | Dec 13th, 2006 08:36 PM |
| GP Workshop Manual and Parts Manual | UBeenMiniD | John Cooper Works & GP | 3 | Nov 9th, 2006 07:51 PM |
| Lsd or not lsd ? that is the question ! | kezman50 | MINI Cooper S | 22 | Nov 27th, 2004 01:24 AM |
| Woohoo I'm regular! | Skinnyrunt | General Discussion | 4 | Mar 9th, 2002 01:32 PM |
