| only the brave! | EML & Engine light keep coming on, Help! Other morning, started the MCS and was idleing really roughly, then noticed that the EML and engine lights were on, turned car on and off a couple off times and the EML light went, so drove 20miles with engine light on, when i stopped and re-started no lights! Same happened yeaterday, but the engine light was on during all of my journies. Then today (when im about to ring the dealership) no lights come at all Anyone seen/dealt with this????? |
| still short!! | I had this sort of problem, but mine came on after the engine cut out while driving down the motorway!! If you leave the ignition on for 5-10 minutes this often cancels the lights, something to do with the exhaust emission sensor re-setting itself I think! Didn't work for me though as a couple of sensors and the throttle housing were goosed!! ![]() |
| Cruising In The Minge | Had the same problem myself a few weeks back. You can try and reset the ECU (disconnect the + battery terminal and touch it against the - terminal then disconnect that terminal too) You wont cause any damage. Leave it for 10 mins then connect them up again. If the problem is still there take it in (mine turned out to be a faulty sensor). ![]() 2002 PS/PS JCW MC 1970 BRG/W MK2 Morris Cooper S |
| Engine & EML Light | Fabio | Faults & Fixes | 30 | Apr 24th, 2008 09:02 PM |
| EML & Engine light keep coming on | venox22 | Faults & Fixes | 0 | Jul 20th, 2005 12:44 PM |
| MINI Stalling, Engine & EML Light coming on | spur | Faults & Fixes | 2 | May 28th, 2005 07:01 PM |
| Check engine light and EML light on for once only??? | oceanstarBug | Faults & Fixes | 1 | May 26th, 2005 02:05 PM |
