| MINI2 Newbie Join Date: Jul 2004 Local Time: 12:54 PM
Offline | More sunroof/performance questions... Have read a lot of posts regarding how a sunroof (with its 60+ lbs) theoretically affects performance. The two camps appear to be: higher center of gravity with increased weight is a double negative; and the difference in performance/handling would be so subtle that the average seasoned/weekend track driver would never noticed. Question: anyone driven both a lot and honestly noticed a difference. May be ordering a new 05 JCW (relatively low frills) and would hate to negate some of the, well, expensive performance gains of the kit. Particularly as I've become accostomed to the handling of a non sunroof MCS. |
| MINI2 Regular Join Date: Feb 2004 Local Time: 04:54 AM
Offline | Unless you're regularly at the top end of fourth gear on tightening radius, off camber sweepers with one and a half turns of opposite lock wound on to counteract lift off oversteer then I don't think you'll notice the extra weight of the sunroof. I love your ideology though. What you may notice (slightly) is a small loss in torsional rigidity as there is a bloomin' great hole where there used to be solid metal. The Mini has a very stiff chassis which shrugs most of this off though. As far as weight is concerned then unless you are trackdaying on a regular basis then the 60lb won't matter either. I guess it depends how obsessive you want to be concerning ultimate performance, were talking fractions here. You'd be as well off wearing shorts and a vest, leaving your small change at home, removing the headrests, floormats and parcel shelf and keeping your hair short, that should save you a good couple of seconds on the school run. Once again, my type of guy, I wish you well. ![]() |
| MINI2 Newbie Join Date: May 2005 Local Time: 04:54 PM
Offline | It depends on you.... Weight is the enemy... Less will make the car more nimble and a bit quicker... If you plan to push your car to the performance edge... then do without... Really up to you... I wanted the most performance out of the S, So I opted to not get the sunroof and went with the LSD. My other car has a sunroof and I never use it.. So its not something I miss... besides.. I get a bit more headroom for a helmet... |
| Enjoy the Journey Join Date: May 2005 Local Time: 05:54 PM
Offline | Sunroof vs Speed etc My view only: Pros: Lets some light in Lets some air in (although air con does it better) Good if you want to look at birds or aeroplanes Cons: Power to weight ratio gets worse Centre of gravity goes up Torsional rigidity decreases Rattles a lot (at least mine did before they stuck a new one in) Tricky one really |
| MINI2 Regular Join Date: Jun 2004 Local Time: 05:54 PM
Offline | I like my sunroof, the thing is I don't know if the car would be faster and have a better handling without a sunroof because I don't know better. Can't compare it. But I can say, my 9 month old 2005 cooper s doesn't have cracks or rattles because of the sunroof. And the car handles great and I don't have any complaints about performance. The car feels very, very solid. I do have cracks from the dashoard and doors, but I read they do have them also without sunroof. Maybe when you are driving your mini on a racetrack then it would matter, but just for 'normal' open road use, take it if you like it. |
| | #6 (permalink) |
| mini beast Join Date: May 2003 Location: Manchester, England Local Time: 04:54 PM
Offline | This may sound rediculous, but has anyone investigated what would be involved in getting their sunroof replaced with a tin-top? Losing 27kg from the roof of the car might be noticeable on trackdays I think, and if the value of the second hand parts (motor, glass, etc) partially offsetted the cost of the work, than I might be interested in giving it a go. It does sound rediculous, doesn't it... |
| | #7 (permalink) |
| MINI2 Newbie | I dunno, you could look at it this way... Look at the lengths some car owners go to just to get rid of 60lbs for the track. Down with Monkey? http://blog.myspace.com/downwardmonkey |
| | #8 (permalink) |
| 05 MCS BEP | In Canada, there is a folding roof option available where the dealer can replace the glass roof with a canvas roof. Should save a few pounds if you want to let the sun in, but the installed price is kind of pricey. 05MCS BEP - Alta 22mm rear anti-swaybar, Madness CAI, (15% pulley soon to be installed) |
| | #10 (permalink) |
| THE STICK Join Date: Feb 2003 Location: Worcestershire WR15 Local Time: 05:54 PM
Offline | The main issue with sunfoof is not really its distribution of weight to the top of the car but the fact it adds huge weight to the car full stop. check out the weights of the cars that ran santa pod at MITP last weekend and you can spot the cars that have sunroofs straight away from the huge differences in weight figures! |
| | #11 (permalink) |
| Back To My Old Self Join Date: Jun 2006 Location: In The Wind Local Time: 05:54 PM
Offline | 60kgs is a lot of weight, ever tried carrying 2.5 bags of cement around? The majority of people would tell you the easiest way to make your car quicker, more efficient & more eco friendly is to reduce the weight. MINI spent a small fortune cutting 40kg out of the GP, so 60kg for a sunroof has to make some difference. I took off my heavy S spoke wheels and replaced with light alloys, saved about 12kg total, and you could feel the difference immediately. As for the weight of some peoples stereo equipment? That would be some system for 60kg . And I thought the idea when you have a brain melting stereo was to drive slowly, hence the term cruise.![]() MODERN MINI - BEST COOPER NOMINEE - PLEASE VOTE FOR ME!!! |
| | #12 (permalink) |
Offline | Mine has a roof and you can feel the difference to car cars that dont have the sunroof! Honest...especially on the track or strip when weight makes a big difference. For your average joe on the road its not woth worrying about but if you want to track it a bit seriously then get a car with tin lid not the glass roof! |
| | #13 (permalink) |
| Overly excited!! Join Date: Aug 2006 Location: Worcestershire Local Time: 05:54 PM
Online | Mine also has 6 airbags, for if I do a 'Crofty' and put the MINI on its roof one day. Be interesting to see how much itactually weighs compared with the chunk of metal taken out. I suppose if there was a fixed carbon fibre section that was lighter than the steel/glass that was there I would consider swapping it if my car was mostly for track work. I certainly have no complaints from having the glass roof there, and I have it open all the time. |
| | #15 (permalink) |
| Blackpool Rock Join Date: Mar 2006 Location: Blackpool Local Time: 05:54 PM
Offline | Your 60lb sunroof equates to about 2.2% of the car weight, losing it is the equivalent of just a 3.7bhp increase for an MCS. Not worth bothering on such a heavy car. Wheels yes as previously mentioned, cos it's a triple hit...... 1 Reduction in unsprung weight, increasing the ratio between sprung & unsprung mass, improving handling 2 Reduction in total car weight 3 Reduction in rotating weight (not only do you accelerate the wheel forward with the car, you also have to accelerate it as a flywheel so weight wise its a double hit) |
| new 06 mini s performance questions | al5774 | General Discussion | 3 | Apr 27th, 2007 09:41 AM |
| 2 questions? handling & performance | chesterbluecoopers | General Discussion | 5 | Nov 17th, 2006 02:53 PM |
| what kinda speed do u realisticaly get out your MC? will sunroof effect performance? | miniisfun | MINI Cooper | 42 | Jan 9th, 2004 04:26 PM |
| Sunroof decal questions | jblow | Exterior | 3 | Sep 11th, 2003 04:21 PM |
| sunroof questions... | Shea-bird | MINI Cooper S | 10 | Jun 12th, 2002 11:22 PM |
