Old Feb 18th, 2008, 08:18 PM   #1
Mess
Go Go Gadget Mini
Mess's Avatar
Local Time: 02:22 AM
Air box Removal
Hi All, just after some quick advice if possible.
Ive remove the stock airbox quite some time back and have now removed the stock plastic air feed pipe for a larger air feed pipe.
What i want to know is where the stock air feed pipe flows into behind the radiator and where the air box fed from there is a black plasic connector box you could call it now sitting there with no viable use that i can see.
Does this feed air to any other part of the engine that i dont know of or can it be removed? If so, how as i cant see to see what its connected to and its pritty loose already.
Mess
United Kingdom Male View Mess's Astro Black & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Feb 19th, 2008, 06:35 PM   #2 (permalink)
Mess
Go Go Gadget Mini
Mess's Avatar
This is the bit that im on about just incase any 1 doesnt know.
Just beind the radiator where the stock box connected to.
what is it connected to and can it be removed?
Name:	IMG_0056 (Medium).jpg
Old Feb 19th, 2008, 07:46 PM   #3 (permalink)
MiniMadMarshy
MiniMadMarshy's Avatar
Hi where is the direct air feed now coming from? Normally when removing the stock air box the feed is left in place to direct air towards the new filter element
Old Feb 19th, 2008, 08:05 PM   #4 (permalink)
Mess
Go Go Gadget Mini
Mess's Avatar
Its now like this:
Old Feb 20th, 2008, 07:27 AM   #5 (permalink)
ScottyBoy
Obsessive Car Cleaner OCC
ScottyBoy's Avatar
I think you will be fine removing that mate.
Old Feb 20th, 2008, 07:52 AM   #6 (permalink)
Mess
Go Go Gadget Mini
Mess's Avatar
how do i remove it tho?
It seems to be attached to something and i cant see what.
Old Feb 20th, 2008, 08:59 AM   #7 (permalink)
ScottyBoy
ScottyBoy's Avatar
Id have to have the car near me to see mate!
Ill see you on the TG run.
Removal of Air-Con GTT 280 Engine & Drivetrain Tuning 12 Jul 20th, 2007 04:23 PM
Fly removal!!!! Liv Maintenance & MINI Care 11 Jun 20th, 2006 10:15 AM
Removal of 135 mph cut off fastfritz Engine & Drivetrain Tuning 38 Dec 11th, 2005 08:32 PM
Wax Removal: HELP! MarylandMade Maintenance & MINI Care 16 Sep 19th, 2004 02:04 AM
Removal of the 'S'!! aus-tim powers Exterior 2 Jan 30th, 2003 11:39 AM
