| MINI2 Newbie Join Date: May 2004 Local Time: 01:23 AM
Offline | cooper spot lights (x4) New Cooper arrived today and very pleased with "Poppy", dealer had fitted 4 spotlights to car instead of a customer's with same surname who was picking their car up after ours. Initially said we could have them for £200 (said they should cost more than £700!!!! which seems very expensive). Alternatively, they would remove them. They then said this would leave holes behind, so we could have them for free. I read here a while ago that BMW had instructed dealers not to fit 4 spotlights due to restricted airflow through grille, but several cars had them fitted for the new registration deliveries today. Also, the car has the 2 spoke mutilfunction steering wheel. The on/off resume buttons light up at night, but not the set +/- buttons. Is this correct and if not, does it need a new sterring wheel assembly or can the affected component be changed? Cheers in advance for your help |
| MINI2 Newbie Join Date: Jul 2004 Local Time: 02:23 AM
Offline | I think you will find that the problem with fitting 4 spots only affects the MCS, as it affects the airflow to the bonnet scoop, or something similar. Keep them, unless you are driving in the countrside at night all the time, and no daylight driving, I can't see the battery running out...wish I got some free ones. ![]() |
| what happened to that boy Join Date: Feb 2003 Local Time: 02:23 AM
Offline | i have 4 operational spot lamps fitted, and yeh its a drain on the batteries, but how often do you drive will your full beam on? besides, you're driving so the power consumption is covered. i'd keep all of em, otherwise disconnect two, but dont remove em. |
| I Just Can't Get Enough | i have 4 on an MCS and don't have any problems with airflow or cooling I have heard this about BMW and the spots but i think they ae just covering their backs and being over cautious But 4 spots on main beam at night is awesome I wouldn't be without them now ![]() ![]() |
| | #9 (permalink) |
| ECMC Addict Join Date: Sep 2007 Location: Essex Local Time: 02:23 AM
Offline | Granny,what a result you lucky so and so ! keep them i say Jordysport, there are a few options, you can fit as 4 seperate lamps or some places sell with a bar to fit the 4 to, rather than stright onto the grille. try one of the sites supporting vendors NewMINIStuff.com, mikey does all things electrical ![]() ![]() JCW Sound Kit No. D0641 |
| Cooper Diesel Spot lights | twentysecondstogo | MINI Cooper Diesel | 14 | Jun 15th, 2007 04:18 PM |
| Spot Lights | Matts Mini Adventure | Exterior | 20 | Oct 26th, 2005 08:54 PM |
| Which Spot Lights to go for ? | DCM | Exterior | 2 | Mar 1st, 2005 04:25 PM |
| aNYONE Got a solid gold mini cooper with aero kit on it and with extra spot lights | TREBALZ | Exterior | 3 | Jan 18th, 2005 01:03 AM |
| Spot Lights On Cooper S | Scott B | Exterior | 16 | Apr 24th, 2004 09:25 AM |
