Old Mar 6th, 2005, 12:25 AM   #1
CNred
Local Time: 02:04 AM
Send a message via AIM to CNred
H&R sway bar
Im considering buying the H&R 18mm rear sway bar, i was just wondering who had put it on and how much of a difference it made. I have the ss+ so its already pretty stiff, im just looking to lose some of the understeer that the cooper has plenty of.
Austin
Old Mar 6th, 2005, 01:52 AM   #2 (permalink)
GregF
GregF's Avatar
Local Time: 05:04 AM
I like this idea as well. It's cheaper than a 19mm bar and probably will make the car neutral (especially a SS Cooper). You could remove your front bar or go to the smaller SS bar, but the labor is more intensive than just putting in a bigger rear bar.
United States View GregF's Cosmos Black & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Mar 6th, 2005, 03:45 AM   #3 (permalink)
CNred
From what i have read the rear sway bar is not that hard of task, more time consuming if anything.(correct me if im wrong) but I hear the front is a more difficult task. Do any companies make a smaller front or does the non ss+ suspension have a smaller sway bar in front and maybe i could pick one up from the factory?
Old Mar 6th, 2005, 12:15 PM   #4 (permalink)
RedUn
MUGEN POWER
RedUn's Avatar
Local Time: 10:04 AM
if i was u i'd just change the rear bar to the one u decided on the front is hmmmm messy to say the least
I tested my car with a 19mm sway bar on the back an std SS bar up front and it did make quite a difference to how quick the car turned and handled
just checked up and there is a 2.5mm difference between the SS and SS+ front bar
Japan Male   Reply With Quote
Old Mar 6th, 2005, 02:36 PM   #5 (permalink)
GregF
GregF's Avatar
Since you already have the plus suspension, removing or changing the front sway bar to SS will keep you in your stock class (H) for autocross. If you move up to a bigger bar in the rear you will need to move to STS, which is much tougher. If you don't autocross or don't plan to, then it's not an issue, unless you worry about your dealer questioning your mods. The labor on the front is at least double the rear. I remember someone saying that it took them 6 hours to do the front.
Here's an old H&R thread that mentions the 18mm bar: http://www.northamericanmotoring.com...highlight=18mm
Old Mar 6th, 2005, 05:01 PM   #6 (permalink)
CNred
i havent autocrossed yet and i dont plan to until im better at driving.I think i will change to the 18mm sway bar when i get my tax return and see how it goes. Thanks for the help
Austin
Old Mar 6th, 2005, 05:25 PM   #7 (permalink)
GregF
GregF's Avatar
Autocrossing is a great way to learn about the limits of your car and improve your skills as a driver. It's you against yourself, just ignore the times of others and compare your own times. It's a lot of fun.
Let us know when you get your sway bar and give us your impressions.
Old Mar 6th, 2005, 06:30 PM   #8 (permalink)
CNred
Autocrossing is something that i definitly want to get into, i just the information from the SCCA about signing up so maybe in a few months i will be improving myself.
Old Mar 7th, 2005, 06:06 PM   #9 (permalink)
pocketrocketowner
Best Personal Regards
The only way to improve your Autocrossing skills is to autocross. It really is a terrific program the SCCA puts on, anywhere near you and it is an awesome way to spend the odd Sunday.....CHEAP to boot!!!
United States Male View pocketrocketowner's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
(JCW) stabiliser / sway bar / roll bar at One B-R Mini MINI One 1 Feb 22nd, 2006 05:31 PM
New 18mm H&R rear sway bar fitted (A couple of questions) Chilipeppa03 Suspension 41 Feb 11th, 2006 05:54 PM
adjustable sway bar & alingment yellow02 Suspension 0 Nov 9th, 2005 10:33 PM
Sway bar help Boonie Suspension 14 Apr 22nd, 2004 09:10 AM
Rear Sway Bar / Anti-roll Bar DragonSean Suspension 7 Apr 20th, 2004 04:17 PM
