| Mad fer it Join Date: Aug 2005 Local Time: 06:26 PM
Offline | Traction Control Hi, i've already searched for this but found nothing so... Is it possible to turn off the traction control on a cooper?? Is traction control the same as this DSC which i keep hearing about, if there is any difference what are they. i see it costs a fair few bob aswell, really not sure if its worth it whatever it is . |
| Four Candles? Join Date: Apr 2003 Location: Hardware Shop Local Time: 06:26 PM
Offline | you just flick the switch when you want to turn it off ![]() The only problem I have is knowing which one to drive? ![]() |
http://www.mini2.com/forum/
| MINI Profiler Join Date: Feb 2001 Location: City By The Bay Local Time: 10:26 AM
Online | Two stability and traction control systems are offered (ASC+T and DSC), with only one (DSC) being available on the Cooper (at least here in the US). I suggest you ... FAQ: What do ABS, ASC, CBC, DSC and EBD mean? ALL forum titles for dsc worth showing threadsLast edited by MINIAC : Sep 5th, 2005 at 12:02 AM. |
| MINI2 Regular Join Date: May 2005 Location: Harvard, MA Local Time: 01:26 PM
Offline | I couldn't find this in an FAQ here, but I thought I remembered seeing something on the MINIusa site. At least in the US, automatic traction control (inexplicably All Season traction Control rather than ATC) is standard for the S (hardtop and convertible) (I'm looking at my 2005 spec sheet -- things may have changed in 2006 and almost certainly are different in different countries). DSC (Dynamic Stability Control) is an option for either Mini Cooper or Mini Cooper S. DSC includes automatic traction control. The 2005 owner's manual has nearly identical descriptions, but says ASC works by reducing engine power or apply brakes to the front wheels, while DSC works by reducing RPMS or applying brakes to individual wheels -- presumably rears as well as front. Both of these can be thought of as anti-lock brakes on steroids. Using the ABS system for traction control is becoming more common even on SUVs since it will work even with open differentials. It does require a more complex ABS system though with individual sensors on each wheel, and individual control of the brakes for each wheel. You can disable ASC using the toggle switch, just as you would for DSC. But it's all or nothing -- if you have DSC you can't switch to an ASC only mode. |
Offline | Just done a search and can't find anything useful really. So reading from your description ASC and DSC does pretty much the same jobs? Does anything come standard on the cooper, if not how much are they in the UK, would really like that DSC thing but ive got so much stuff to buy before uni im not sure if i should go for it. For people with it, do you think it is worth it? Another thing, if i dont decide to have it put on the car can i go back and have it 'put on' later on? Last edited by Wooly : Sep 4th, 2005 at 11:58 PM. |
| | #6 (permalink) |
Online | DSC is an expansion of ABS and ASC+T ... did you read the FAQ? According to the MINI UK configurator ASC+T and DSC are available on the Cooper as £100 and £320 options. I found a half dozen "Is DSC worth it?" threads using the search criteria I posted in my previous thread ![]() ![]() |
| | #7 (permalink) |
Offline | Ah thanks mate, ive just been on uk mini site aswell and found out it only costs £100. But im still not entirely sure of what it is. what im after is something like...on my mates civic he has a switch which can turn off the traction control and itll snake its way all the way up the road if you floor it. if i get this DSC thing and turn it off surely that will mean im back where i started with a standard cooper dont it , im after something to turn off the traction completly. |
| | #11 (permalink) |
Offline | if you don't buy it you don't have it to turn off, its like if you don't buy a kettle then you have not got a kettle to worry about if its on or off The only problem I have is knowing which one to drive? ![]() |
| | #15 (permalink) |
| MINI2 Master Join Date: Dec 2004 Local Time: 06:26 PM
Offline | my cooper cam totaly standard not a single option on it ie not asc+t or dynmic stabilaty meaning it has more of a pull away than you might whant some times but i love it without all the electronic stuff ![]() |
| | #16 (permalink) |
| In exile, down SOUTH! Join Date: Aug 2001 Location: London WC1 Local Time: 06:26 PM
Offline | If you don't order ASC + T (or front fogs), then it means one of the toggle switch will be missing on the panel, a number of people considered that as unsightly, and bought blank switch to cover it ![]() DK :apple: |
| | #17 (permalink) |
| Toon Toon.. <div><a href= Join Date: Aug 2001 Location: Up North Local Time: 06:26 PM
Offline | Ok...if you don't buy ASC + T you will have NO traction control on your car. If you pay for the £100 option then you will have the choice of whether to have it on/or not. i.e. Flick the ASC + T toggle switch on/off. And that's all there is to it. ![]() Global Moderator ![]() |
| | #18 (permalink) |
![]() What's this button do? Join Date: Jul 2004 Location: Our Own Little World Local Time: 12:26 PM
Offline | Ordering ASC+T or DSC doesn't give you the ability to turn them off, but rather the ability to have them on... FWIW, on this side of the great water, there seems to be a sudden shift to include some sort of traction control (with or without an off switch) on pretty much everything. I would imagine this will lead to higher resale values in a few years for cars that came with it before everybody had it. I happen to like the DSC on our Cooper and find it very effective (and I rarely turn it off)... -Eric |
| Traction Control on/off | Adamm1985 | General Discussion | 3 | Jul 11th, 2007 05:51 PM |
| Traction Control | Adrian_T | Engine & Drivetrain Tuning | 20 | Mar 29th, 2006 04:11 PM |
| Traction Control | Angel_1701 | Faults & Fixes | 0 | Dec 17th, 2005 12:25 PM |
| Who needs traction control...... | Charger_Pete | General Discussion | 18 | Oct 29th, 2004 03:19 PM |
| Traction Control | NutTheBus | MINI Cooper | 10 | Apr 9th, 2002 06:09 PM |
