When does turbo get involved for Countryman S? - MINI Cooper Forum
MINI Countryman MINI Countryman 2010 - Present
post #1 of 5 (permalink) Old Jan 18th, 2014, 10:11 AM Thread Starter
Local Time: 05:17 PM
United States Male
United-States When does turbo get involved for Countryman S?
As far as I know, turbo only get involved when rpm is higher than some certain number, what is it? Does Sport mode make the turbo be involved earlier?
beaver is offline
post #2 of 5 (permalink) Old Jan 18th, 2014, 10:33 AM
Local Time: 12:17 AM
Quoted: 39 Post(s)
No, the turbo is working all the time, though at very low revs and small throttle openings it doesn't do a lot. Peak torque starts at 1600rpm so at that point the turbo is working flat out when the throttle is wide open.
As far as I'm aware, sport mode only alters throttle response (that is, the throttle is opened further for the same amount of pedal travel) and automatic transmission shift points - it doesn't alter the engine behaviour, just the 'feel'.
Angib is offline
post #3 of 5 (permalink) Old Jan 22nd, 2014, 11:57 AM
Local Time: 01:17 AM
Quoted: 1 Post(s)
England
I believe the sport button also makes the steering heavier.
Tabintab is offline
post #4 of 5 (permalink) Old Feb 10th, 2014, 03:04 AM
CCroker's Avatar
Local Time: 06:17 PM
Quoted: 27 Post(s)
United States Male
Only if you have the Sport Package will the button give you full Sport. Including the 198Lbs of torque at 3800rpm.
Charlie Croker ,BRG 03 Cooper S, SCCA Solo, PDX, Time Trials, RoadRally, and Stella, 011 Oxford Grn Countryman S, with complete Sport Package, stock at present
CCroker is offline
post #5 of 5 (permalink) Old Mar 4th, 2014, 04:30 PM
SGT Slaughter & Farm Girl
Local Time: 08:17 PM
United States Male
United-States Turbo and Sport mode.
The Sport button gives you a sharper throttle response, Tightens up the steering and Automatics have their Shift points changed. Little sharper and crisper if your carving some twisty roadways.
Mini_drive is offline
DIY: Changing the orange turbo seal MiniDeLux MINI Cooper Diesel 1 Dec 30th, 2014 12:43 PM
Soot around turbo and tractor noise during left-hand cornering sebster MINI Cooper Diesel 14 Aug 19th, 2013 08:58 AM
Dead Turbo needs replacing in 1.6 dooper Porn_Star19 General Discussion 0 Jan 24th, 2013 11:37 AM
2007 R56 MCS Turbo blowing/damaged Sharkn3t Second Generation MINI Cooper S 6 Jan 23rd, 2013 11:02 AM
Loose turbo inlet pipe; beware Jonnyfive Second Generation Faults & Fixes 1 Aug 8th, 2012 03:06 AM
