Intermittent acceleration issue on CM S 2012 - MINI Cooper Forum
MINI Countryman MINI Countryman 2010 - Present
post #1 of 3 (permalink) Old Mar 19th, 2014, 08:48 AM Thread Starter
Local Time: 04:56 AM
United States Male
United-States Intermittent acceleration issue on CM S 2012
Had this issue a couple of times before and after I replaced my clutch. It occurred when I accelerate aggressively (not floor the throttle though) in any gear, the car shakes back and force after the clutch is fully engaged while accelerating, dissapears after release the throttle. Anyone has the similar issue? Since this is an intermittent issue, not been able to show it to dealer and get it fixed.
beaver is offline
post #2 of 3 (permalink) Old Mar 19th, 2014, 09:56 AM
Local Time: 12:56 PM
Quoted: 53 Post(s)
Are you sure its not just tramping? where the wheels are asked to get grip suddenly and attempt to spin but because the road surface has a non smooth grip like finish the wheels grip and slip and grip until the power eases off a little?
Do you have traction control fitted.
The Nun is offline
post #3 of 3 (permalink) Old Mar 20th, 2014, 07:29 AM Thread Starter
United States Male
probably, I have habit to turn off the traction control right after start up, I will try tmr without turning that off.
beaver is offline
Stop start intermittent issue andrew007007 Second Generation Faults & Fixes 4 Mar 31st, 2014 09:21 PM
