LED Headlights 2013 Countryman - MINI Cooper Forum
MINI Countryman MINI Countryman 2010 - Present
post #1 of 5 (permalink) Old Jun 22nd, 2014, 09:58 PM Thread Starter
Local Time: 11:05 AM
I just put in a LED headlights conversion kit into my wife's 2013 Countryman all4. Now every time you go to start the car the light emblem appears where the digital speed is in the tac, if you hit the reset button it goes away. The headlights seem to work fine. I was just wanting to know if this is normal. The lights are from Oracle lighting. This is also in the United States.
anthf3 is offline
post #2 of 5 (permalink) Old Jun 23rd, 2014, 08:14 AM
Local Time: 05:05 PM
Quoted: 53 Post(s)
LED lights use less power than conventional bulbs so if the system originally had normal lighting it is probably thinking the low power consumption means a bulb fault so its warning you of possible bulb failure etc?
Maybe, I would think, you might have to have the computer re coded so that it recognises what youve done so the light doesnt keep appearing, or fit some kind of resistor in the supply to the light to fool it into thinking nothing has changed?
The Nun is offline
post #3 of 5 (permalink) Old Jun 24th, 2014, 02:17 AM Thread Starter
Ok, that makes since. Thanks for your help.
anthf3 is offline
post #4 of 5 (permalink) Old Sep 7th, 2014, 01:25 AM
Local Time: 02:05 AM
Australia
Was the upgrade worth it?
The lights in my wife's 2007 Cooper S are crap and I have been thinking about the led conversion. Would you recommend it?
TonyWalsh is offline
post #5 of 5 (permalink) Old Sep 17th, 2014, 01:59 AM
Quoted: 1 Post(s)
England
Answer = No.
Try uprated bulbs like philips 50% brighter. There are lots to choose from.
The conversion kits replace the bulb & are known the dazzle oncoming traffic as the reflectors are s**t in all standard headlight minis..
It is possible to dismantle the headlight assemblies and fit lenses that make the lights work like oem. Even then you don't have washers that are mandatory or self leveling and its a lot of work.
Tabintab is offline
2013 Mini Cooper S Countryman Cross Bar mrxs3xy Welcome New Members 0 Mar 4th, 2014 07:12 PM
MVP Track Time 2013 Track Dates Feffman Mini Events 1 Jul 26th, 2013 10:06 PM
2013 Countryman Changes Blackhawks MINI Countryman 5 Nov 15th, 2012 02:32 PM
