Think Mini
Old Jan 25th, 2007, 04:37 PM   #1
Fabio
F43i0
Fabio's Avatar
Local Time: 11:08 PM
Send a message via MSN to Fabio Send a message via Skype™ to Fabio
Question Track Day Tyre Pressure
Hi
i'll be tracking my MINI for the first time this weekend and i'd like to get to info on tyre pressure for the track day.
I was given guideline tyre pressure from timmydamini (33psi Front, 30 Rear, Thanks ). From what i've gathered that after the first session the tyre pressure will rise, so after the first session do i control the tyre pressure and let some air out til i get to 33psi Front and 30 rear???
Also i've read that its better to run on a higher psi, so that the tyre wall is firmer so the tyre wears less and wears more evenly? so do i still let the air out after the first session or do i run at a higher psi cause 33 and 30 is a standard road driving psi?????
One more thing, if i do have to let air out after the first session, will the air expand as much on the 2nd and 3rd session??
thanks
Fabio
Old Jan 25th, 2007, 05:14 PM   #2 (permalink)
dukesantos
Moderator
dukesantos's Avatar
Local Time: 04:08 PM
Here's an older thread that should help.
http://www.mini2.com/forum/mini-moto...res-track.html
United States Male View dukesantos's Pure Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 29th, 2007, 07:57 PM   #3 (permalink)
s_and_m
220 of your finest horses
s_and_m's Avatar
Local Time: 12:08 AM
Send a message via MSN to s_and_m
What track?
What track are you running on?
My advice re pressures is to go up to 34 front and 36 back (for a little added rear wheel steer) and adjust the pressure throughout the day.
Typically, after the first session I bleed out some air and then it stays pretty much constant until the tyres cool down - mind you I do use sticky R888s on the track.
Above all - enjoy!
S
England Male View s_and_m's Liquid Yellow & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Thunderhill Track day 7-6-2006, lots of track time, low cost! ThePerfectLine Northern California Region 0 Jun 26th, 2006 09:59 PM
Track day tyre choice Tonyt3 Wheels, Tyres & Brakes 20 May 29th, 2006 06:07 PM
Track Day Tyre Pressures REHW MINI in Motorsport 24 Sep 8th, 2005 08:23 PM
