Mini Cooper N/A rally build - Page 3 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > All Models & Variants > MINI in Motorsport
MINI in Motorsport For everything to do with MINI in motorsport
  #31 (permalink)
Old Dec 21st, 2012, 04:33 PM
Local Time: 12:05 PM
Costa Rica
Here's the nearly finished dash. and the Mini in the customs jail along with all the cars no one cleared!
Amazing I did the clutch alignment by eye sight with the box fitting on perfect! Now time to relax until I get the Mini back in Mid January
  #32 (permalink)
Old Jan 21st, 2013, 02:05 PM
Costa Rica
Finally got the Mini out of the customs! did the stud conversion on the front
  #33 (permalink)
Old Jan 23rd, 2013, 09:30 PM
Paul@1320's Avatar
MINI2 Sponsor
looking good
  #34 (permalink)
Old Jan 27th, 2013, 07:36 PM
Costa Rica
Thanks Paul..
As you know I'm using STI struts on the front and it looks likely I'll be using STI on the back. Mini damper is on the left.
The old and the new!
  #35 (permalink)
Old Feb 7th, 2013, 04:58 PM
Costa Rica
On Feb 10th I'll be off back down to CR with STI rear dampers, adjustable brake bias, Hydraulic hand brake, battery boot relocation, sadly the oringinal radiator as my WRX conversion will not be allowed in the rules plus a bunch of other stuff and decals. The goal is to have the engine running by the end of Feb. First rally date is April 14th. More photos to follow.
  #36 (permalink)
Old Feb 9th, 2013, 04:15 PM
Costa Rica
one of the most popular questions I get is to why did I go with Subaru STI for my suspension. 1/ good past experience 2/ cost 3/ gravel spec availability . There seems to be a ton of tarmac spec dampers but nothing for gravel at a cost I can afford. I'm using road dampers to start with, then could use this set up. Ksport Adjustable Coilover Systems, Camber Kits and Suspension Products | Ksport Store
  #37 (permalink)
Old Feb 21st, 2013, 11:56 AM
Italian Stallion
Looking good mate
  #38 (permalink)
Old Feb 21st, 2013, 01:19 PM
Costa Rica
Thanks Corey
This visit I got the cam shaft in and most of the engine parts back where they should be. With a few hours work I was able the fit the Subaru STI rear dampers to the R56 trailing arm. Work required was to make a new top mount using Subaru/Mini , bore out the bottom bolt hole to 14mm and grind a little bit off the trailing arm. Ride height went up by 3/4" and I get around 1 1/2" extra . travel. Brake line I will attach later.
  #39 (permalink)
Old Feb 21st, 2013, 01:43 PM
Italian Stallion
Is it hard to change the ride hight? Can you do it yourself or do you need a macanic?
  #40 (permalink)
Old Feb 21st, 2013, 04:57 PM
Costa Rica
depends how good you are with the spanners but saying that you have to be creative. I'm wanting a Plus ride height not minus like most folks as I'm going to be on gravel stages.
  #41 (permalink)
Old Mar 3rd, 2013, 10:36 PM
Costa Rica
The engine is back together less the radiator and S oil heat exchanger. The radiator I left off as I plan to fit a new alternator and S oil heat exchanger on my next visit. The rear STI suspension, R56 trailing arms and Helix lateral arms are fitted. Steel trailing arm weighs 23lbs, the R56 15lbs, Steel laterals 8LBs a pair, Helix 4Lbs a pair. So 22lbs less of unsprung weight. Next trip back won't be until March 27th with the first rally being April 14th. I'm going to be really busy to finish on time but if not the next rally is in May. Last thing I want to do is rush and miss something important.
  #42 (permalink)
Old Mar 9th, 2013, 02:15 PM
Local Time: 01:05 PM
Belgium Male
very good job !
  #43 (permalink)
Old Apr 8th, 2013, 03:14 PM
Costa Rica
Wow! That was a very hot weekend and working outside does not make things any easier. The other problem is being Costa Rica it's not easy to get parts. Imagine I need some long 10mm bolts to mount the shifter. I couldn't find any so I had to weld 3 bolts together! Also I needed 90 angle hoses for the S oil heater exchanger which I'll have to get from the US. Anyway after many hours slaving over a hot Mini the office is taking shape. I have both hydraulic and cable hand brakes for 2 reasons. 1/ I need cable for the tech test(this is a daily driver) 2/ if I lose the brakes on a rally I still have a mechanical back up! Notice the rust? just a few days in the humid weather. I'm going to paint it soon.
The engine is done. I did the battery cut off and fire system pull recessed as in rallying we tend to go off into bushes etc so the last thing I need is a branch setting off the fire system. Also the scuttle grills now act as heat out vents for the engine.
I used the Helix short shifter , which makes the shift very nice.
This badge should give the other teams something to worry about..hahaha
  #44 (permalink)
Old May 20th, 2013, 03:47 PM
Costa Rica
This visit has been the most productive so far; everything seemed to go right for a change! Hahaha I figured out my wiring issues and finished the front of the car apart from the Strut/chassis bar which I plan to make when the car is on the road. The wiring DUH! Was I cut the CAN bus to the IKE thinking this was part of the airbag wiring as it’s the same colour wire. I pretty sure now everything will work again as all the modules can chat to each other. I finished the under body protection brackets and fitted a hose to provide fresh air to the power steering pump area. Also I like to have to have foam between the skid plate and engine to stop stones gathering there which could make a hole in the sump. Another job finished was the recessed battery cut off and fire system deployment lever. Fitting the poly suspension control arm bushes was very easy. ½ hour right side and 45 mins left side. Just unbolt the ball joints, use a 5/16 drill to remove as much rubber bushing as possible then use a bar to pry out the arm. Use a sazall to carefully cut the outer metal so it pops out. Don’t go nuts here as you could cut the housing up! . To fit the poly bush I used a cheap 3 arm hub puller with the arms removed. Then made a plate to push in the bush, add some soap and in about minute the bush was in. Then use an angle grinder to cut the old bush off the arm and refit the arm on the car. Done! Now the front was done I could finally fit the front bumper to make the Mini whole again! Before fitting the wheels I added the mud flaps needed for rallying….just finished that job when the heavens opened! Rain stopped play.
  #45 (permalink)
Old May 20th, 2013, 06:42 PM
mab01uk's Avatar
Great work and thanks for posting the latest photos of your rally MINI.......also glad that you seem to have sorted out those wiring problems!
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
Rally MINI Build on Men & Motors mab01uk MINI in the Media 1 Sep 13th, 2008 05:15 AM
Rally MINI build on TV now (12.25) mab01uk General Discussion 0 Sep 7th, 2008 11:55 AM
build your own mini cooper £5 @ play itsonrails Models Collectables & Collectibles 0 Aug 27th, 2008 03:05 PM
MINI.ca updated: build yer own Cooper (S) tripwire General Discussion 10 Feb 11th, 2003 02:28 PM
Mini Cooper UK Build Dates Razor General Discussion 6 May 1st, 2002 09:12 PM
